Closed loop vs. stepper motors -advice sought November 07, 2015 10:40PM |
Re: Closed loop vs. stepper motors -advice sought November 08, 2015 05:28AM |
Admin Registered: 18 years ago Posts: 14,162 |
Re: Closed loop vs. stepper motors -advice sought November 08, 2015 04:07PM |
Re: Closed loop vs. stepper motors -advice sought November 08, 2015 04:21PM |
Re: Closed loop vs. stepper motors -advice sought November 08, 2015 04:22PM |
Re: Closed loop vs. stepper motors -advice sought November 09, 2015 04:50AM |
Re: Closed loop vs. stepper motors -advice sought November 09, 2015 05:59AM |
Re: Closed loop vs. stepper motors -advice sought November 09, 2015 07:44PM |
jappiemike
Hello gentlemen,
I have been thinking of my next Arduino/Mbed project and a 3d printer/router/SLS/powder printer seems the go. I've been thinking of building a 500mx500mm welded steel (50x25mm sections) bed machine and using linear encoders along the X and Y axis to give me the accuracy that C7 ballscrews apparently won't. When using encoders why do you use quadrature code when you already know the direction the bed is moving having started to drive the motor clockwise or anticlockwise? Would using smallish DC brushed or brushless, I haven't decided on the pros and cons yet, through a zero backlash worm drive to give the higher torque be the best way to go? Because of the size of the axis would a central driving structure with supported linear rails on the outer extremes be as good as 2 drive structures alongside the rails to combat racking? And finally if I do manage to close the loop can I use a timing belt instead of the ball screws, at the moment I'm not intending to cut anything stronger than wood so there shouldn't be too much of a problem with stretching the belts.
Cheers
Mike
Re: Closed loop vs. stepper motors -advice sought November 09, 2015 08:26PM |
Anonymous User
Re: Closed loop vs. stepper motors -advice sought December 11, 2015 02:36AM |
Re: Closed loop vs. stepper motors -advice sought December 11, 2015 06:54PM |
Re: Closed loop vs. stepper motors -advice sought December 14, 2015 07:23AM |
Re: Closed loop vs. stepper motors -advice sought December 16, 2015 09:48AM |
Re: Closed loop vs. stepper motors -advice sought December 29, 2015 10:34PM |
Re: Closed loop vs. stepper motors -advice sought February 29, 2016 11:58PM |
Re: Closed loop vs. stepper motors -advice sought March 01, 2016 03:05AM |
Re: Closed loop vs. stepper motors -advice sought March 01, 2016 06:59AM |
Re: Closed loop vs. stepper motors -advice sought March 01, 2016 09:59AM |
Anonymous User
Re: Closed loop vs. stepper motors -advice sought March 01, 2016 10:31AM |
the_digital_dentist
Can anyone tell me what benefit would come from replacing steppers with the complication and expense of servo motors?
Re: Closed loop vs. stepper motors -advice sought March 01, 2016 10:51AM |
Anonymous User
Re: Closed loop vs. stepper motors -advice sought March 01, 2016 11:00AM |
dc42
I think the main advantage of using servo-controlled motors to control the XYZ axes of a 3D printer instead of steppers would be that it would avoid the possibility of missed steps.
Re: Closed loop vs. stepper motors -advice sought March 01, 2016 11:31AM |
Re: Closed loop vs. stepper motors -advice sought March 03, 2016 01:50AM |
dc42
Re: Closed loop vs. stepper motors -advice sought March 04, 2016 05:01AM |
