Lead Screw usage for X and Y axes January 09, 2016 03:43PM |
Re: Lead Screw usage on X and Y axes January 09, 2016 04:08PM |
Re: Lead Screw usage on X and Y axes January 09, 2016 04:13PM |
Re: Lead Screw usage on X and Y axes January 09, 2016 04:42PM |
use ... motors with low inertia (short ones)
I used the motor sizing tools at the Oriental Motor website to calculate the torque required to drive the Y axis in my printer
Re: Lead Screw usage for X and Y axes January 09, 2016 05:04PM |
Re: Lead Screw usage on X and Y axes January 09, 2016 05:29PM |
tobben
Wow, that's a solution I hadn't thought of. So a short NEMA23 is better than a longer NEMA17 assuming all other specs equal. How great is this effect? Just making up an example: How much acceleration would a 42mm NEMA23 gain compared to a 60mm NEMA17 just from being short (depends on lead screw of course, say 10 mm per rev or something)?
Re: Lead Screw usage for X and Y axes January 09, 2016 05:32PM |
I can keep you updated if you'd like.
Re: Lead Screw usage on X and Y axes January 09, 2016 05:41PM |
Using leadscrews, you are likely to need less torque but more speed than for a belt-driven X or Y axis, ...
Re: Lead Screw usage on X and Y axes January 09, 2016 06:44PM |
Re: Lead Screw usage on X and Y axes January 10, 2016 02:56AM |
tobben
Hm... You really know the trade offs between Nema 17 and Nema 23, dc42. I think I understand most of it. Short Nema 17 is what we want then.
Nice! With no experience of lead screws from before, I was expecting the opposite.
Re: Lead Screw usage on X and Y axes January 10, 2016 09:35AM |
the_digital_dentist
You won't know how much torque you need until you know all the moving masses (rotational and linear) and the losses such as stiction and friction.
the_digital_dentist
Any money spent on a "short NEMA-17 motor" at this early stage is likely to be wasted- short NEMA-17 motors don't produce much torque.
dc42
Do the sums before you buy any motors.
Re: Lead Screw usage for X and Y axes January 10, 2016 09:49AM |
albatroopa
Here's a render of what i have so far
Render
and here's the bill of materials:
BoM
What's inside the V-shaped end?|
Anonymous User
Re: Lead Screw usage for X and Y axes January 10, 2016 10:27AM |
) for 3D printers when cheap timing belt seems to provide enough accuracy and are so simple to use, low inertia, no noise, no play leading to backlash unless high quality ball lead screws, no lubrication and thus no dust lubricant mess etc... |
Re: Lead Screw usage on X and Y axes January 10, 2016 12:18PM |
Re: Lead Screw usage for X and Y axes January 10, 2016 12:23PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Lead Screw usage for X and Y axes January 10, 2016 12:41PM |
Re: Lead Screw usage for X and Y axes January 10, 2016 01:03PM |
Re: Lead Screw usage for X and Y axes January 10, 2016 01:16PM |
Re: Lead Screw usage for X and Y axes January 10, 2016 01:44PM |
the_digital_dentist
I have 1/2" lead acme screws in the Z axis of my printer. See if you can spot any problems:
As I only sort of understand it, Imperial threads are only a problem when the pitch is small.
Anonymous User
Re: Lead Screw usage for X and Y axes January 10, 2016 03:01PM |
Re: Lead Screw usage for X and Y axes January 10, 2016 03:12PM |
Re: Lead Screw usage for X and Y axes January 10, 2016 03:37PM |
Re: Lead Screw usage for X and Y axes January 10, 2016 08:46PM |
MKSA
I wouldn't buy a non ISO compliant machine.
Anonymous User
Re: Lead Screw usage for X and Y axes January 11, 2016 03:11AM |
the_digital_dentist
MKSA
What is an ISO compliant machine? ISO 8217? ISO 26000? Which ISO spec pertains to 3D printers?
Re: Lead Screw usage for X and Y axes January 11, 2016 05:11AM |
Re: Lead Screw usage for X and Y axes January 13, 2016 10:03AM |
Re: Lead Screw usage for X and Y axes January 13, 2016 11:01AM |
Re: Lead Screw usage for X and Y axes January 13, 2016 11:13AM |
Re: Lead Screw usage for X and Y axes January 13, 2016 12:29PM |
Re: Lead Screw usage for X and Y axes January 13, 2016 02:19PM |
cozmicray
Probably too expensive for your application
