Anonymous User
Re: Lead Screw usage for X and Y axes March 04, 2016 12:16PM |
tobben
We're spoiled
But shouldn't a few cleverly coupled components like coils, capacitors and a resistors be able to give a normal a4988 the slight phase shift it needs, just around the resonant frequencies?
I would expect the total cost of the needed component to be < $10. Manually adjusting a potentiometer to adjust a filter to hit the right frequency bandwidth for my setup would be a low additional cost.
Anonymous User
Re: Lead Screw usage for X and Y axes March 04, 2016 12:20PM |
the_digital_dentist
I see at least one motor mounted in printed plastic. I hope it isn't PLA- the heat from the motor is going to soften the plastic and cause no end of problems.
I recently replaced a printed ABS motor mount from my printer with an aluminum part. When I looked at the plastic, I found that screw holes had distorted due to heat and tension from the belt. If that happens to ABS, PLA is going to be a disaster.
Re: Lead Screw usage for X and Y axes March 04, 2016 02:03PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Lead Screw usage for X and Y axes March 04, 2016 03:46PM |
Re: Lead Screw usage for X and Y axes March 04, 2016 04:31PM |
Re: Lead Screw usage for X and Y axes March 04, 2016 10:25PM |
Re: Lead Screw usage for X and Y axes March 05, 2016 08:37AM |
Re: Lead Screw usage for X and Y axes March 05, 2016 10:10AM |
Re: Lead Screw usage for X and Y axes March 05, 2016 10:13AM |
tobben
deaconfrost
As it is the printer tops out at around 25mm/s to 30mm/s I don't think it go any faster with 1 start.
Is it mid-band resonance that limits the speed? (would look like these videos: [1], [2], [3]).
BTW, found a video showing anti-resonant drivers + rotating the nut: [4] The cheapest anti-resonance stepper drivers I've found are $40 each [5]. This makes cheap leadscrew + anti-resonance driver a cheaper option than branded aggressive leadscrew + cheap driver. Still not cheap though...
I wonder why anti-resonance drivers are so expensive? The problem of resonance seems easy enough to understand (mass/spring system [6], [7]) and the solution of electronic damping seems simple enough to implement at home [8].
Re: Lead Screw usage for X and Y axes March 05, 2016 10:56AM |
Re: Lead Screw usage for X and Y axes March 05, 2016 10:59AM |
Re: Lead Screw usage for X and Y axes March 05, 2016 04:00PM |
Re: Lead Screw usage for X and Y axes March 05, 2016 06:24PM |
Anonymous User
Re: Lead Screw usage for X and Y axes March 06, 2016 01:30PM |
Re: Lead Screw usage for X and Y axes March 07, 2016 06:55PM |
Anonymous User
Re: Lead Screw usage for X and Y axes March 08, 2016 01:58AM |
deaconfrost
MKSA
deaconfrost
Yea I should find that out in couple weeks, have 4 start leadscrew ordered
From what I see, when one axis moves, the other axis carriage is moving too with the head isn't ?
sorry but I don't get what you asking
Re: Lead Screw usage for X and Y axes March 08, 2016 08:27PM |
Anonymous User
Re: Lead Screw usage for X and Y axes March 09, 2016 03:50AM |
Re: Lead Screw usage for X and Y axes March 09, 2016 07:41AM |
Re: Lead Screw usage for X and Y axes March 09, 2016 12:30PM |
Re: Lead Screw usage for X and Y axes April 21, 2016 11:43AM |
Re: Lead Screw usage for X and Y axes April 21, 2016 11:59AM |
Re: Lead Screw usage for X and Y axes April 21, 2016 12:41PM |
Re: Lead Screw usage for X and Y axes April 21, 2016 02:47PM |
Should I do a separate sale thread as well??|
Anonymous User
Re: Lead Screw usage for X and Y axes April 23, 2016 07:44AM |
tobben
Hi albatroopa! Sorry for not updating this thread, I'm writing my Master's =)
Here's a little prototype I built last week, just to see how simplistic linear actuators inspired by deaconfrost's printer would look like:
I'm aiming for extreme ease of build, teach and usage because the Master's is about designing an assembly workshops. Here's my latest sketch of how to deal with alignment:
I'd like to measure the need for thrust bearings when I get the time...
wrong !|
Re: Lead Screw usage for X and Y axes April 23, 2016 08:38AM |
Anonymous User
Re: Lead Screw usage for X and Y axes April 23, 2016 09:54AM |
albatroopa
Lol, thanks for clearing that up MKSA. Thrust bearings ALONG WITH the regular bearings is the plan, I believe. And it's actually a very good idea. In case you can't tell, this is what we call a mock-up, and it's a pretty good start.
I'd love for you to elaborate on your input though.
One suggestion I would make is to put the motor for your X axis outside of the motor mount so that your leadscrews can have a bearing at each end instead of relying on the motor bearings. Also to add in cross bracing on the bearing and motor supports and make them thicker.
Re: Lead Screw usage for X and Y axes April 23, 2016 10:19AM |
Re: Lead Screw usage for X and Y axes April 23, 2016 12:49PM |
Yes, motor and bearing supports are very easily twisted. I'm reluctant to cross braces because it would double the unique parts count per linear actuator. I'm going to test clamping the XY-gantry to a steel/aluminium sheet first, and measure the XY-axes' twistability. I'm expecting the Z-axis to become very easily twisted, but I suspect that I will prefer to mitigate this by beefing up the Z-rail holders, along the lines of the_digital_dentist's comment, instead of adding cross braces. I'll keep cross braces in mind if the prototype surprises me though (and they often do).Quote
albratroopa
the_digital_dentist
Why weaken it? Are you trying to save a few cents worth of plastic?
Re: Lead Screw usage for X and Y axes April 23, 2016 01:35PM |
