Which bed should i purchase for print under 100 microns ? March 03, 2016 01:59PM |
Anonymous User
Re: Which bed should i purchase for print under 100 microns ? March 04, 2016 02:13AM |
conG
Hi !
Actually, i have an alu bed which has a flatness tolerance of 0.2mm!! between two corners.
I'm working on a new printer and i would like to have some advice about what i should buy to have an enough flatness tolerance for printing under 100 microns, like 0.01mm ...
Any suggestions ?
Re: Which bed should i purchase for print under 100 microns ? March 04, 2016 11:01AM |
Re: Which bed should i purchase for print under 100 microns ? March 04, 2016 02:09PM |
Re: Which bed should i purchase for print under 100 microns ? March 04, 2016 02:14PM |
Re: Which bed should i purchase for print under 100 microns ? March 04, 2016 04:39PM |
Re: Which bed should i purchase for print under 100 microns ? March 04, 2016 06:40PM |
Re: Which bed should i purchase for print under 100 microns ? March 05, 2016 03:37AM |
Re: Which bed should i purchase for print under 100 microns ? March 05, 2016 03:51AM |
conG
Good! but i would say, it's a little bit tricky to say "you can print at 50 microns but only in the center of the bed".
conG
An other goal is to have a printer who can be reliable and that any anonyne ubsers can use without knowing anything but the printer it-self (without building it, or simply working out-of-the-box).
Anonymous User
Re: Which bed should i purchase for print under 100 microns ? March 05, 2016 05:19AM |
conG
I saw in the community's space Ultimaker that users can print to 60 microns without any problems. My main goal is to be as precise as possible (no replicable, under 1K€). I know that usual reprap can have a precision of 5 microns in THEORY because you can't print as lower as that for few reasons (structure rigidity, bed flatness, ...).
This is what i'm going to work on it !
Re: Which bed should i purchase for print under 100 microns ? March 05, 2016 08:24AM |
conG
Good! but i would say, it's a little bit tricky to say "you can print at 50 microns but only in the center of the bed". An other goal is to have a printer who can be reliable and that any anonyne ubsers can use without knowing anything but the printer it-self (without building it, or simply working out-of-the-box).
conG
What about taking a large bed and cutting at a lower size if the center is all-right ? Is this at this step that edge are curving around ?
Re: Which bed should i purchase for print under 100 microns ? March 06, 2016 04:51AM |
Re: Which bed should i purchase for print under 100 microns ? March 06, 2016 09:07AM |
MKSA
I would like to see a reprap with a 5 micron precision. Neither in theory (people should learn more about theory !) nor practice. Precision, is for all 3 axes, too. ...
Besides, we are dealing with a filament of molted plastic !
