steps per mm for belt driven leadscrews June 23, 2016 05:47AM |
Re: steps per mm for belt driven leadscrews June 23, 2016 08:25AM |
Re: steps per mm for belt driven leadscrews June 23, 2016 01:59PM |
Re: steps per mm for belt driven leadscrews June 23, 2016 02:16PM |
Re: steps per mm for belt driven leadscrews June 23, 2016 02:24PM |
Re: steps per mm for belt driven leadscrews June 23, 2016 02:30PM |
Re: steps per mm for belt driven leadscrews June 23, 2016 03:57PM |
Re: steps per mm for belt driven leadscrews June 23, 2016 04:09PM |
Well, yeah, guess I was also overthinking it.Quote
the_digital_dentist
The OP asked what is the gear ratio of a 32 tooth pulley driving a 20 tooth pulley. The word "ratio" tells you what to do: 32/20 is the ratio, by definition.
That's a bit stupid way of solving it, if you have known constants of the parts.Quote
cozmicray
How about
with known Steps / mm set in firmware
Command Z axis movement A
Measure the Z Axis distance moved B
A little calculation
Reset steps/mm
until
commanded distance = distance moved
Record result --- so you can put it back when the EEPROM loses it.
Re: steps per mm for belt driven leadscrews June 23, 2016 07:38PM |
Mikk36
You might get even false results from that with bad measurements.
Re: steps per mm for belt driven leadscrews June 24, 2016 05:40AM |
Re: steps per mm for belt driven leadscrews June 24, 2016 08:21AM |
