Troubles with the second extruder
Posted by Elstak
January 29, 2017 03:33AM
Hi
Sorry if i use the international section instead of the italian one but i need support to fix a problem.
Yesterday i tried to print using also the second extruder but the motor just produce noise. The sound is like the motor start loosing steps so i tried to change the motor, the driver, the wire... nothing change (of course the motor work well if i connect to E0).
The board is a MKS 1.4(MK4duo 4.3.1), i tried with TC2100, A4988 and DRV8825; AWG26-24-22 cables... but i experience the same result, the motor loose steps.
Need I a new board?
Thanks
Re: Troubles with the second extruder
January 29, 2017 03:48AM
Can you extrude filament by turning it by hand? If not it might not be the extrude but the hotend.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
January 29, 2017 09:59AM
Srek
yes, the hotend work fine, also the motor if connected to the E0 and the E1 driver work if placed on E0 so i think is the board....
Edited 1 time(s). Last edit at 01/29/2017 09:59AM by Elstak.
