21:12:04.890 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
21:12:04.894 : echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
21:12:04.894 : echo:Home offset (mm)
21:12:04.894 : echo: M206 X0.00 Y0.00 Z0.00
21:12:04.898 : echo:Material heatup parameters:
21:12:04.898 : echo: M145 S0 H180 B70 F0
21:12:04.898 : M145 S1 H240 B110 F0
21:12:04.898 : echotongue sticking out smileyID settings:
21:12:04.902 : echo: M301 P22.20 I1.08 D114.00
21:12:04.902 : echo:Filament settings: Disabled
21:12:04.902 : echo: M200 D3.00
21:12:04.902 : echo: M200 D0
21:12:05.356 : Printer reset detected - initalizing
21:12:05.356 : start
i cant print the object when i click on print with the software " repetier host " choose sli3ce , and the software heat up my heat head nozle ( with thermsitor + step motor ) and after when the nozzle hit the temp 200 degree C and the software wont allow me to print or sometimes the x , y , z run everywhere dont know how to stop either me push on the estop x , y they wont stop , only click on emergency stop on the repetier host software , anyone have any idea how to fix it? All my x y z axis is correct demission My board is RAMPS 1.4 Arduino Mega 2560
