how to fix it filament disable???????
March 12, 2017 12:30AM
21:12:04.890 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
21:12:04.894 : echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
21:12:04.894 : echo:Home offset (mm)
21:12:04.894 : echo: M206 X0.00 Y0.00 Z0.00
21:12:04.898 : echo:Material heatup parameters:
21:12:04.898 : echo: M145 S0 H180 B70 F0
21:12:04.898 : M145 S1 H240 B110 F0
21:12:04.898 : echotongue sticking out smileyID settings:
21:12:04.902 : echo: M301 P22.20 I1.08 D114.00
21:12:04.902 : echo:Filament settings: Disabled
21:12:04.902 : echo: M200 D3.00
21:12:04.902 : echo: M200 D0
21:12:05.356 : Printer reset detected - initalizing
21:12:05.356 : start
i cant print the object when i click on print with the software " repetier host " choose sli3ce , and the software heat up my heat head nozle ( with thermsitor + step motor ) and after when the nozzle hit the temp 200 degree C and the software wont allow me to print or sometimes the x , y , z run everywhere dont know how to stop either me push on the estop x , y they wont stop , only click on emergency stop on the repetier host software , anyone have any idea how to fix it? All my x y z axis is correct demission My board is RAMPS 1.4 Arduino Mega 2560
Re: how to fix it filament disable???????
April 12, 2017 01:24AM
The filament will only go by the gear if the extruder lever is released. But you can only get the filament to the right spot by having the lever pushed down. You want the power off so the gear will turn from the filament pushing by it. After filament is changed then home x and y, in this way it does not matter if they move. The printer knows where to go to. The problem with move while change the filament is that the moves are not controlled by the printer and it loose sense of where it is, but after a home of x and y it should know where it is.
Edited 1 time(s). Last edit at 04/12/2017 01:26AM by Ericlkelly.
Website
