"direct drive" extruder with stationary mounted motor March 24, 2017 10:13PM |
Re: "direct drive" extruder with stationary mounted motor March 25, 2017 08:08PM |
Just looking at specifications on the THK website, 6mm shaft should be able to handle the torque. According to the specs on a 300mm 6mm linear rail (not ball spline, but it should have roughly the same weight) on amazon, one 300mm rail weighs 70 grams.
You only need to push one rail, but obviously there are the spline nuts, gears, ball bearings for the gears, and whatever frame all of these items are contained within. My ballpark guess would be 150g for a 300mm system. High torque nema 17 steppers run between 400 and 500 grams. So there should be some significant weight savings, although the cost and added complexity will still make it prohibitive for most.
Edit:
I did some math to verify the weight of the shaft.
ASTM spec 52100 bearing steel density: 7.81g/cm3
6mm shaft @ 300mm = 8.48cm3
Calculated weight = 66.25g
Re: "direct drive" extruder with stationary mounted motor March 25, 2017 08:47PM |
Re: "direct drive" extruder with stationary mounted motor March 26, 2017 07:09AM |
Re: "direct drive" extruder with stationary mounted motor March 26, 2017 03:30PM |
Re: "direct drive" extruder with stationary mounted motor March 26, 2017 04:07PM |
Re: "direct drive" extruder with stationary mounted motor March 26, 2017 06:18PM |
Re: "direct drive" extruder with stationary mounted motor March 26, 2017 06:41PM |
Re: "direct drive" extruder with stationary mounted motor March 27, 2017 12:26AM |
Re: "direct drive" extruder with stationary mounted motor March 27, 2017 09:33AM |
Re: "direct drive" extruder with stationary mounted motor March 28, 2017 04:32AM |
infiniteinquiry
I figured there must be something comparable out there in the wild. I searched around though, and never got any results when searching for "ball spline" and extruder. So at least that is something somewhat original.
Ball splines:
[www.nbcorporation.com]
I like the Mendel/i3 implemention with a single axis version you shared. Why isn't this more popular? I'm working on a custom build ultimaker style, so that's what I've been focused on.
Re: "direct drive" extruder with stationary mounted motor April 09, 2017 10:35AM |
Re: "direct drive" extruder with stationary mounted motor June 08, 2017 09:01AM |
Re: "direct drive" extruder with stationary mounted motor August 27, 2017 02:43PM |
