Hello
I changed the standart bed system to an CORE XY and upgraded firmware properly. It worked fine so far with printing. It has now been a while since i used this printer (1month) and i was trying to print something. But the printbed hardley move. The Stepper motor sound weird and shake pretty strong. I checked the Voltage for the Stepper each at 0.56 Volt. For the driver.
The mechanic works fine when i move it via hand. Anyone have a suggestion? Can it be the Repetierhost which i downloaded? I thougth i just have to set the settings in the firmware for CORE xy or do i have to set it in repetierhost aswell?
The Config file is changed in unccomend corexy and change the step rate of the first to values to 100
Greetings Losspost
