Dual extrusion setup - Which to choose? November 09, 2017 05:01PM |
Re: Dual extrusion setup - Which to choose? November 11, 2017 05:38AM |
Re: Dual extrusion setup - Which to choose? November 11, 2017 06:39AM |
Re: Dual extrusion setup - Which to choose? November 11, 2017 01:13PM |
Re: Dual extrusion setup - Which to choose? November 11, 2017 01:31PM |
Re: Dual extrusion setup - Which to choose? November 15, 2017 07:38PM |
Re: Dual extrusion setup - Which to choose? November 17, 2017 05:06AM |
StephenM
I think the way forward for multi-extrusion is via a tool changer.
I am working on a design for independent tool heads. Each one would have it's own "umbilical cord" for wiring, reverse bowden, flex/nimble style remote extruder drive, and possibly water cooling lines and Berd-Air cooling (as chamber will likely be heated).
Corexy gantry "cart" would simply pick whichever head is selected.
Clamping via kinematic coupling and magnet(s).
XYZ offsets handled in software, so they don't have to be physically identical.
Ideal nozzle geometry and temps for each material.
1) PLA
2) PVA
3) CF Nylon
4) Flexible TPU
Anyways, that's my plan.
Re: Dual extrusion setup - Which to choose? November 17, 2017 07:12AM |
Re: Dual extrusion setup - Which to choose? November 18, 2017 01:16AM |
Re: Dual extrusion setup - Which to choose? March 25, 2018 12:25PM |
Re: Dual extrusion setup - Which to choose? March 25, 2018 02:26PM |
Re: Dual extrusion setup - Which to choose? March 25, 2018 03:25PM |
Re: Dual extrusion setup - Which to choose? March 26, 2018 05:44PM |
Re: Dual extrusion setup - Which to choose? May 13, 2021 05:52AM |
Thank you for the thread and links, pals, a lot of useful information. I'm a newbie, just started. Still have a lot of doubts, what is the best printer with IDEX configuration for the start.Quote
dc42
Probably the best option for dual-material is IDEX (independent dual X carriages), but this requires much greater modifications to the printer.
Ian (deckingman) is an expert on Diamond hot ends, both 3- and 5-input versions. His blog is at [somei3deas.wordpress.com]. Click on tag "Diamond hot end".
