Dual motor and belt on Z November 28, 2017 08:07AM |
Re: Dual motor and belt on Z November 28, 2017 08:21AM |
Re: Dual motor and belt on Z November 28, 2017 08:40AM |
Re: Dual motor and belt on Z November 28, 2017 04:02PM |
Blackgnome
Got plenty of steppers/leadscrews/pullys/belts and probe solutions laying around, building a corexy just for fun and to try out diffrent solutions atm and this just got me thinking that 2 should give some extra torque for those Heavy lifting/holding jobbs
So it is possible and should not be a problem, will try this to see how it goes. Worst case I´ll just use the good old 1 motor/pulleys/belt solution.
Thanks.
Re: Dual motor and belt on Z November 29, 2017 04:24PM |
Re: Dual motor and belt on Z December 03, 2017 01:52AM |
MKSA
Blackgnome
Thanks.
This solution is old because it is good ! Like the round wheel is still with us while all the inventors of the square wheel have been quickly forgotten. It is why they keep popping up regularly
Re: Dual motor and belt on Z December 03, 2017 03:33AM |
Blackgnome
Re: Dual motor and belt on Z December 03, 2017 08:32AM |
Re: Dual motor and belt on Z December 03, 2017 09:27AM |
JonathanThompson
MKSA
Blackgnome
Thanks.
Skateboarders that have tried them swear by them! (Truth is often stranger than fiction: wheels that are both square AND round!)
I have no connection to the sellers or creators or any financial ties, I just couldn’t resist responding
[www.amazon.com]
Re: Dual motor and belt on Z December 13, 2017 07:37AM |
Srek
Instead of two motors you should use a single one with sufficient power. There simply is no need for a second one since the leadscrews will lock anyway (except if you use the wrong ones) and the power required for lift should usually does not exceed what a 1.7A NEMA 17 can deliver.
