Dual motor and belt on Z
November 28, 2017 08:07AM
Any comments on the idea of using dual motors for Z and connecting them with a belt ?
Is this like begging for problems in case of 1 motor missing a step or could this help
kepping the bed in level even if 1 motor skips a step or 2 ?
Re: Dual motor and belt on Z
November 28, 2017 08:21AM
Good solutions are:
A. A single Z motor, driving 2 or 3 screws through pulleys.
B. 2 or 3 Z motors driven from separate stepper drivers, and use firmware and a Z probe to perform automatic levelling after homing (the firmware adjusts the Z motors individually to get the bed level).
Both of these solutions avoid the problem of multiple Z stepper motors getting out of sync.
Regarding your suggestion of dual Z motors connected by a belt, that should be viable. Motors slip 4 full steps at a time, not 1 full step, so the pulleys need only be large enough to constrain the relative movement to within +/-2 full steps. Using 1.8deg motors, this is +/- 3.6 degrees. The tooth width of a 20-tooth pulley is 9 degrees; so 20-tooth pulleys should be sufficient if the belt is tight.
However, if you will be using a belt and pulleys, why not use just one motor?
Edited 3 time(s). Last edit at 11/28/2017 08:25AM by dc42.
November 28, 2017 08:40AM
Got plenty of steppers/leadscrews/pullys/belts and probe solutions laying around, building a corexy just for fun and to try out diffrent solutions atm and this just got me thinking that 2 should give some extra torque for those Heavy lifting/holding jobbs winking smiley
So it is possible and should not be a problem, will try this to see how it goes. Worst case I´ll just use the good old 1 motor/pulleys/belt solution.
Thanks.
November 28, 2017 04:02PM
Blackgnome
Thanks.
This solution is old because it is good ! Like the round wheel is still with us while all the inventors of the square wheel have been quickly forgotten. It is why they keep popping up regularly smiling smiley
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
November 29, 2017 04:24PM
If you need more power, using 1 motor give you the opportunity to gear up. Use a small pulley on the motor, and larger ones on the screws. It lowers maximum speed but this isn't important on Z. Also still cheaper then 2 motors.
December 03, 2017 01:52AM
MKSA
Blackgnome
Thanks.
Skateboarders that have tried them swear by them! (Truth is often stranger than fiction: wheels that are both square AND round!)
I have no connection to the sellers or creators or any financial ties, I just couldn’t resist responding winking smiley
[www.amazon.com]
December 03, 2017 03:33AM
Blackgnome
Have you considered a belt-lifted Z axis?
December 03, 2017 08:32AM
Instead of two motors you should use a single one with sufficient power. There simply is no need for a second one since the leadscrews will lock anyway (except if you use the wrong ones) and the power required for lift should usually does not exceed what a 1.7A NEMA 17 can deliver.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
December 03, 2017 09:27AM
JonathanThompson
MKSA
Blackgnome
Thanks.
[www.amazon.com]
Yet an hybrid but anyway, fame at last, after more than 5000 years of trying smiling smiley
Edited 1 time(s). Last edit at 12/03/2017 09:29AM by MKSA.
December 13, 2017 07:37AM
Srek
Ordered a extra Nema 17 with almost twice the Power just in case. This is at the moment a build for testing ideas on, considered a beltdriven Z but will be a later test.
