Replace timing belts with FireLine March 24, 2018 07:30AM |
Re: Replace timing belts with FireLine March 24, 2018 04:02PM |
Re: Replace timing belts with FireLine March 24, 2018 04:14PM |
Re: Replace timing belts with FireLine March 25, 2018 04:20AM |
Re: Replace timing belts with FireLine March 25, 2018 05:52AM |
o_lampe
BTW: There is no material without stretch, especially when it's braided. ( hard to see on your pic, but definitely the case in the video)
We had a discussion about spectra line vs. belt lately...
Re: Replace timing belts with FireLine March 25, 2018 04:14PM |
Re: Replace timing belts with FireLine April 05, 2018 01:47AM |
Re: Replace timing belts with FireLine April 08, 2018 06:13PM |
Re: Replace timing belts with FireLine April 09, 2018 12:04AM |
Re: Replace timing belts with FireLine April 09, 2018 02:19AM |
Re: Replace timing belts with FireLine April 09, 2018 04:45AM |
Trakyan
Interesting to hear about the more windings increasing wear and not helping much with reducing slip. Do you know for sure it's the fact there are more windings causing the extra wear and not just the seam in the 2 part pulley? Really curious to know more about this since I'll be using this sort of system in a higher load situation where slipping is more of an issue.
Re: Replace timing belts with FireLine April 09, 2018 04:51AM |
Re: Replace timing belts with FireLine April 10, 2018 02:07AM |
Re: Replace timing belts with FireLine April 10, 2018 02:07PM |
o_lampe
Please finish this statement:
Restricting the cord-travel along the pulleys would end in _________.
Re: Replace timing belts with FireLine April 11, 2018 07:44AM |
Re: Replace timing belts with FireLine April 11, 2018 12:39PM |
Re: Replace timing belts with FireLine April 11, 2018 06:42PM |
o_lampe
IMHO, the scary thing about fishing line printers is the insane amount of tension required to prevent slipping.
So I thought of a different approach which doesn't require excessive tension. ( I'm sure it's been done before )
We could clamp the fishing line to the pulley, so it can't slip. Now we have to wind up the right amount of line to the pulley required to do the whole travel.
With a bit of tinkering, we could share that amount of turns equally between drive pulley and idler.
Let's say, the drive and idler both have a diameter of 10mm = 31.4mm per turn and we want 300mm travel. That's 5 turns on each side. Not too much I'd say.
Re: Replace timing belts with FireLine April 12, 2018 02:30AM |
Re: Replace timing belts with FireLine April 12, 2018 05:39AM |
Re: Replace timing belts with FireLine April 14, 2018 08:56AM |
Re: Replace timing belts with FireLine April 14, 2018 11:05AM |
o_lampe
Just uploaded a short video to demonstrate the shared windings and such.
The setup isn't perfect. The idler bracket should be fixed. I thought it would help aligning and centering.
Re: Replace timing belts with FireLine April 14, 2018 11:51AM |
Re: Replace timing belts with FireLine April 14, 2018 05:29PM |
Re: Replace timing belts with FireLine May 03, 2018 04:11AM |
Re: Replace timing belts with FireLine May 03, 2018 06:24AM |
Re: Replace timing belts with FireLine May 04, 2018 02:49AM |
Re: Replace timing belts with FireLine May 04, 2018 04:49PM |
Re: Replace timing belts with FireLine May 05, 2018 03:07AM |
Re: Replace timing belts with FireLine May 05, 2018 04:04AM |
Re: Replace timing belts with FireLine May 17, 2018 10:25AM |
