Re: Replace timing belts with FireLine May 18, 2018 01:48AM |
Re: Replace timing belts with FireLine May 18, 2018 01:50AM |
Re: Replace timing belts with FireLine May 20, 2018 08:18PM |
Re: Replace timing belts with FireLine May 21, 2018 02:24AM |
Re: Replace timing belts with FireLine May 21, 2018 03:09AM |
Re: Replace timing belts with FireLine May 21, 2018 06:40AM |
Re: Replace timing belts with FireLine May 22, 2018 03:36AM |
You haven't seen my video? The line is fixed....Quote
You can additinally fix the line in the middle of the spoolers, so there is no spinning.
Re: Replace timing belts with FireLine May 22, 2018 06:22AM |
Re: Replace timing belts with FireLine May 23, 2018 03:32AM |
At the risk of sounding stupid/blind, where's the video?Quote
o_lampe
Re: Replace timing belts with FireLine May 23, 2018 11:47AM |
Re: Replace timing belts with FireLine May 23, 2018 12:12PM |
Re: Replace timing belts with FireLine May 23, 2018 01:01PM |
Re: Replace timing belts with FireLine May 23, 2018 09:11PM |
Re: Replace timing belts with FireLine May 24, 2018 01:10AM |
Re: Replace timing belts with FireLine May 24, 2018 02:10AM |
Re: Replace timing belts with FireLine May 24, 2018 06:12PM |
Re: Replace timing belts with FireLine May 24, 2018 06:32PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Replace timing belts with FireLine May 24, 2018 07:28PM |
Re: Replace timing belts with FireLine May 25, 2018 02:10AM |
JoergS5
For big printers you will need thicker wires, e.g. the Sli3dr creator will switch to wire for a tension of 60 kg. In my calculation this means FireLine above 0,5 mm diameter. I plan to use wire for a small printer (MGN07 linear guides and Bowden) and will try FireLine 0,1 mm, where angles and tensions should not be a problem if the stepper pulley is large enough.
Re: Replace timing belts with FireLine May 25, 2018 02:13AM |
Trakyan
This may seem like a stupid idea, but what if we "synchronize" the travel of the string on the spool with the travel of the carriage. So as the carriage moves towards the spool, the string is wound so that it moves closer to the notch (ridge?) at the center of the spool.
Re: Replace timing belts with FireLine May 25, 2018 04:27AM |
Trakyan
What sort of drive system did you use VDX? A pulley with the line anchored to it or just relying on friction to run it like a belt?
Re: Replace timing belts with FireLine May 25, 2018 01:35PM |
Re: Replace timing belts with FireLine May 25, 2018 06:50PM |
The string can leave the pulley at an angle, I'd love to draw a picture but I'm working the majority of the weekend, I'll see if I can draw it next week.Quote
o_lampe
Trakyan
With a fixed connection between carrier and string, the string would then always have to be in the center of the pulley? I don't see clearly, what you mean.
Re: Replace timing belts with FireLine May 26, 2018 03:24AM |
Trakyan
20mm is too small for most steel wires.
Also, doesn't spectra have lower stretch than steel per unit area? Maybe it was mass/density, can't remember.
Re: Replace timing belts with FireLine May 26, 2018 05:01PM |
Re: Replace timing belts with FireLine May 26, 2018 05:44PM |
Re: Replace timing belts with FireLine May 26, 2018 05:54PM |
Re: Replace timing belts with FireLine May 26, 2018 07:54PM |
Re: Replace timing belts with FireLine May 27, 2018 04:48AM |
Re: Replace timing belts with FireLine May 27, 2018 07:41AM |
