Non-Captive / Hollow stepper motor for smooth rods
May 27, 2018 08:56AM
I need to have a stepper motor in the middle of a long (500mm) smooth shaft, as i need output on both ends. Non-Captive steppers seem to be made for threaded acme lead screws, hollow steppers seem made to allow for wires or other items through the middle.
I want to insert a 8mm shaft through a nema 17/23 stepper and secure it to the middle of the smooth shaft, I can grind a flat spot to secure it,
Makerparts.ca
Your Canadian source for V-Slot Extrusion, CNC and 3D Printing Parts and Accessories.
we are proud to be an official Openbuilds distributor.
Re: Non-Captive / Hollow stepper motor for smooth rods
May 28, 2018 02:01AM
Why not use a dual shaft stepper and add couplers and smooth rods on both sides?
May 28, 2018 12:43PM
I used a Rino worm drive in the Z axis of my printer. The output is a keyed, 8 mm hole. I used an 8mm shaft with a keyway cut into it. You may not want the 30:1 gear reduction that the worm drive provides, depending on your application. In my printer's Z axis, the worm drive prevents the bed from falling when motor power is cut.
The red part in the center is the gearbox.
you can see it a little better here:
Edited 1 time(s). Last edit at 05/28/2018 12:44PM by the_digital_dentist.
May 30, 2018 01:50PM
Thanks Mark. Every time I read your comments or blogs, you give me new construction ideas!!
Your Z construction is what I plan roughly (with double shaft Stepper, but without gearbox) for my Y Axis in a dualwire-gantry printer. But using it for Z is a great idea also.
