upgrading printer
October 03, 2018 07:01AM
Does anybody have some close pictures of new printers like this
http://www.nexi-tech.com/wp-content/uploads/2017/05/Snap-2017-05-22-at-18.36.05-1282x500.png
I like to upgrade my Z and X axis with gears like this on picture.
Is it possible to buy that spare parts somewhere?
If not if someone have printer please put some close pictures here to see how it is build.
Thank you.
Re: upgrading printer
October 03, 2018 10:24AM
just looks like a cr10
have a bigger image (click on it, twice, to get full size)
there are lots of parts on aliexpress
not sure what gears your referring to...
its basically a vslot machine with rollers running on the vslots and belts in the slots.
In case you haven't heard of vslot
So its like tslot, but has a v groove to so its easy to use it as cheap linear rails
Edited 3 time(s). Last edit at 10/03/2018 10:34AM by Dust.
October 04, 2018 01:01PM
It would be nice for you to tell us what printer
you are going to upgrade?
confused smiley
October 04, 2018 01:42PM
It is HIC printer, made from alu profiles.
But it will be more like build new printer from old one, because I will change almost all.
What is my major concerne is that movable parts have almost none tolerance, of shaking and vibrating.
October 04, 2018 03:43PM
Blisk
Are you concerned with frame/bracket stiffness, or linear slide stiffness?
For Z-axis frame stiffness, supports are an easy solution:
Z-Braces
Re-designed brackets could easily be made stiffer as well.
October 06, 2018 05:24PM
Keep this printer to print parts.
Build up another printer to meet all your requirements / desires
Sounds like you want MAJOR update!
You can get all the parts on eBay or other outlets.
Gears? Do you mean leadscrews to drive X?
The CR-10 variant you show uses timing belts on X, Y
and lead screw on Z.
confused smiley
