using non-idler pulleys as idlers directly on the shaft - no bearings December 02, 2018 04:17AM |
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 02, 2018 07:58AM |
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 02, 2018 02:59PM |
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 02, 2018 04:26PM |
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 02, 2018 05:26PM |
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 02, 2018 06:25PM |
Ed3D
Is there any negative to using F695 idlers on the toothed side of the belt? Im concerned that it will damage the teeth or is it not an issue?
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 03, 2018 01:59AM |
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 03, 2018 02:33PM |
ruyvieira
Ed3D
People think it will give you extra-ripply vertical surfaces and flatten your belt and or shred it, but in practice it's fine, lots of commercial printers do that (Lulzbot Taz, Makergear M2 and most of the Creality 3d printers)
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 05, 2018 03:40PM |
Re: using non-idler pulleys as idlers directly on the shaft - no bearings December 05, 2018 03:54PM |
gmedlicott
Flanged bearings work better than (cheap) pre-made idlers but not because the bearings are better quality. The idlers have the two bearings pressed in with the outer races contacting the idler, but the inner races free. When you tighten the bearing axially, the inner races load up and make it hard to turn.
