Build Plate Design December 29, 2018 03:57AM |
Re: Build Plate Design December 29, 2018 11:06AM |
Re: Build Plate Design December 29, 2018 12:29PM |
Re: Build Plate Design December 30, 2018 02:49AM |
Re: Build Plate Design December 31, 2018 04:46AM |
the_digital_dentist
4 leveling screws doesn't make much sense if you recall from high school geometry that 3 points define a plane. See: [drmrehorst.blogspot.com]
When you heat the plate it will expand (about 0.5mm if you heat it to 100C to print ABS). That will push the leveling screws sideways and something will have to bend/move. Will your plate stay level or at least return to level every time it heats up? That potential problem can be mitigated by using a kinematic mount.
Mark Rehorst
All are flat enough for edge to edge printing in 200 um layers. I can't say how big the bed can get and still be rigid enough to stay flat enough to print on with only 3 screws supporting it. That will depend on the thicknesses of the bed plate and the first print layer. Larger printers are typically used to print larger objects in thicker layers, and thicker layers are more tolerant of variations in flatness, so I suspect that 3 point leveling can be used to go quite a bit larger than 300 mm square, unless you're trying to print a 50 um first layer.
o_lampe
Other people have used magnetic foil or sheet instead of seperate magnets
Re: Build Plate Design December 31, 2018 06:12AM |
Re: Build Plate Design December 31, 2018 08:41AM |
Re: Build Plate Design December 31, 2018 04:28PM |
Re: Build Plate Design January 01, 2019 01:48AM |
