Filament throat opinion wanted (full metal vs. PTFE lined) February 04, 2019 07:54PM |
Re: Filament throat opinion wanted (full metal vs. PTFE lined) February 04, 2019 10:06PM |
Re: Filament throat opinion wanted (full metal vs. PTFE lined) February 04, 2019 10:14PM |
the_digital_dentist
The teflon liner is fine, except when it goes into the heater block, in which case it will break down due to the high temperature in the heater block and cause jams instead of preventing them.
All metal is the way to go, especially if you want to print anything like ABS, PC, nylon, etc.
Re: Filament throat opinion wanted (full metal vs. PTFE lined) February 05, 2019 01:44AM |
Re: Filament throat opinion wanted (full metal vs. PTFE lined) February 05, 2019 09:48AM |
dc42
Teflon liner works great if you only print PLA. It can tolerate much more retraction than an all metal hot end so it is less prone to jamming. For any other filament i advise an all metal hot end.
Re: Filament throat opinion wanted (full metal vs. PTFE lined) May 06, 2019 09:41AM |
Admin Registered: 11 years ago Posts: 3,096 |
dc42
