Dual Z stepper motor sync with linear rail carriages October 09, 2019 07:08AM |
Re: Dual Z stepper motor sync with linear rail carriages October 09, 2019 09:56AM |
Re: Dual Z stepper motor sync with linear rail carriages October 09, 2019 10:44AM |
Re: Dual Z stepper motor sync with linear rail carriages October 11, 2019 05:04AM |
dc42
There are various automatic ways of levelling the motors if they get out of step and you use separate drivers:
- Reduce motor current and stall-home them against individual Z max physical endstops
- Use a separate endstop switch for each motor, then home them simultaneously but independently
- Use the Z probe to probe 2 or more points on the bed, then the firmware computes and applies the corrections required to individual motors
HTH David
Re: Dual Z stepper motor sync with linear rail carriages October 11, 2019 05:12AM |
the_digital_dentist
There's another option- use one motor and belt the two Z axis screws together. They will never get out of sync because they can't (at least as long as the set screws in the pulleys are tight).
Re: Dual Z stepper motor sync with linear rail carriages October 11, 2019 05:51AM |
MKSA
the_digital_dentist
Why make it simpler, cheaper, better ? So much fun trying to fix issues one creates
Re: Dual Z stepper motor sync with linear rail carriages October 11, 2019 08:49AM |
imotion
While I will always consider a belt driven dual Z axis, I have the same confidence in a grub screw being able to maintain the grip required to clamp a pulley to a leadscrew (unless it has been ground flat in that spot) as I do when it comes to the use of 2 seperate steppers.
Something about a motor on one side just doesnt give me the feeling that the gantry is being raised in equilibrium. I am pondering whether to throw a belt across the top and retain the motors on the bottom (both sides) to force it in sync six ways from sunday. Remembering these are pancake steppers, a bigger motor placed on one-side would most likely foul on the gantry before the nozzle was able to reach the bed - which was placed as low to the bottom of the frame as possible. Not that any loss of Z is a big problem, but the low profile bed is an important aspect of the design intended to minimise negative effects associated with non-coreXY designs (where the bed does not have to move back and forth whatsoever)
Re: Dual Z stepper motor sync with linear rail carriages October 22, 2019 03:08AM |
Re: Dual Z stepper motor sync with linear rail carriages October 22, 2019 06:56AM |
Re: Dual Z stepper motor sync with linear rail carriages October 26, 2019 08:04AM |
Re: Dual Z stepper motor sync with linear rail carriages October 26, 2019 12:08PM |
Re: Dual Z stepper motor sync with linear rail carriages October 26, 2019 01:28PM |
Rewas
You might find some good ideas for a belted Z from this build. I'm intrigued by his 5:1 pulley reduction versus a worm gear box for the Z axis.
[elitemachineworks.com]
Re: Dual Z stepper motor sync with linear rail carriages October 27, 2019 09:13AM |
