Triple Z Axis June 01, 2020 04:13AM |
Re: Triple Z Axis June 04, 2020 01:25AM |
Re: Triple Z Axis June 04, 2020 03:38AM |
Re: Triple Z Axis June 04, 2020 03:49AM |
JoergS5
In most cases it is recommended to use two linear guides and a three point bed. The best explanation about the bed I know is:
[drmrehorst.blogspot.com]
and you can find valuable other construction ideas from him in his other blogs also which I recommend much.
Re: Triple Z Axis June 04, 2020 03:54AM |
Re: Triple Z Axis June 04, 2020 03:58AM |
JoergS5
I expect 4 mm for a 400x400 too thin, I would take 8 or more mm thickness. As material so-called MIC6 aluminium (= cast aluminium plate) is a good choice.
