V slot wheels on precision shafts June 17, 2020 07:08AM |
Re: V slot wheels on precision shafts June 17, 2020 08:06AM |
Re: V slot wheels on precision shafts June 17, 2020 09:45AM |
the_digital_dentist
As my rustic grandmother in the Tennessee hill country used to say, "you can't make a silk purse out of a sow's ear".
Adding shoulder screws won't change the fact that the surface the wheels are riding on is not ground and polished to ensure flatness or straightness. It also won't ensure that the molded plastic wheels are round, smooth, and perfectly centered on the bearings, and have a perfectly smooth surface, or that the bearings don't wobble.
All that said, the are plenty of good printers that use t- or v-slot systems. I wouldn't worry about substituting shoulder screws for whatever comes with the kit. Build the kit and then start picking at it based on things you don't like that you see in the prints or the way the printer forces you to operate it, or things you want to do with it but can't. I suggest you do what I did after I built my first printer. Every time you run into any kind of problem that is a function of the way the printer is built or the way it has to be operated because of the controller, etc., add it to a list. It doesn't matter. If it bothers you, put it on the list. After a few months you'll have a long list of stuff. Once you've run out of things to put on the list, rank each item in terms of importance - it might be important because it makes doing certain things difficult or because it affects print quality. Next, for each of the items, make a list of possible solutions. Don't get sold on a solution that fixes a couple problems and then try to shoehorn it into fixing other problems- make the list first. After you've made the list of potential fixes for the problems, start to look for commonalities. Maybe replacing wheel axles with shoulder screws will be in there, maybe it won't. Maybe you'll decide that the controller has to be replaced with something better. Maybe that will solve 10 problems at once (assuming you pick the right new controller). At some point you can also factor in the cost of the fixes. You might find that $50 well spent will fix 90% of the problems and that fixing the the last 10% will cost $500. You'll have to decide what your tolerance for pain is...
Re: V slot wheels on precision shafts June 18, 2020 05:37PM |
Re: V slot wheels on precision shafts June 18, 2020 06:40PM |
Re: V slot wheels on precision shafts June 19, 2020 02:32AM |
the_digital_dentist
It's hard to argue with the quality of those prints.
Re: V slot wheels on precision shafts June 19, 2020 07:35AM |
Re: V slot wheels on precision shafts June 19, 2020 06:48PM |
the_digital_dentist
I prefer my machines to be well built, too, with minimal software tricks to try to compensate for a poor mechanical build. I have access to materials (cheap t-slot, cheap cast plate) and machine tools (Milwaukee Makerspace) that a lot of people don't, so the software tricks are useful for people who have to rely on others to cut parts accurately, or are stuck with printed parts in critical positions.
Re: V slot wheels on precision shafts June 20, 2020 08:14AM |
hobbymods
Yes, you are lucky to be so well equipped and supplied. The US must be awesome for niche hobbyists.
There's no such thing as cheap cast plate in Australia, but I do have access to a water jet cutting guy who takes care of me. I don't have anything that would cut or machine aluminium to the tolerances required, which is why I've opted for a frame kit.
I do have the gear to make really good wiring harnesses in silicone RC wire, and can crimp any of the little plugs (with my glasses on) we use, so there's no solder joints/slicing in my wiring. Good connections and cable routing certainly help.
I did just order a second set of Z and X gantry plates for this kit. It cost bugger all and will be handy to have them there just in case.
Re: V slot wheels on precision shafts June 20, 2020 06:08PM |
sdavi
hobbymods
Few of years ago when i was building my printer, finding a place that had the reprap favourite MIC6 here in aus wasn't easy. I ended up using a piece of 6.35mm cast ATP-5 from a place in Syd that was also happy to cut a piece the size i wanted (270x230mm).
Re: V slot wheels on precision shafts June 20, 2020 09:06PM |
hobbymods
Was that "Calm Aluminium"?
I got them to cut me a piece of 1/4" (which is 6.35mm) for my Zortrax conversion. Mine is "Vista Metals ATP5" as well. I don't know if that's better or worse than MIC6, but that's all I could find as well.
It wasn't perfectly flat by the way, but still pretty good compared to any other plate I've used and heats nicely.
Re: V slot wheels on precision shafts June 20, 2020 09:14PM |
sdavi
hobbymods
Yeah that was the place. Mine has a very slight fall in one corner but the main printing area is flat and probably more importantly remains flat when heated. It was still one the best upgrades to my printer though.
Re: V slot wheels on precision shafts June 22, 2020 12:55AM |
Re: V slot wheels on precision shafts June 23, 2020 04:40AM |
Re: V slot wheels on precision shafts June 23, 2020 07:22AM |
Re: V slot wheels on precision shafts June 23, 2020 08:22AM |
Re: V slot wheels on precision shafts June 23, 2020 09:44AM |
Re: V slot wheels on precision shafts June 23, 2020 10:28PM |
hobbymods
MIC-6 is 7000-series (purer aluminum IIRC) and is softer and more difficult to mill; ATP-5 and Alca 5 are both 5083 aluminum-magnesium alloy and are harder and mill more easily; they have less thermal expansion and I think around 1% lower thermal conductivity. All three have consistently good results reported for 3d printing.
Re: V slot wheels on precision shafts June 26, 2020 07:12AM |
