Large machine with light X-carriage - Which motion system? September 15, 2020 04:48AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Large machine with light X-carriage - Which motion system? September 15, 2020 06:18AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Large machine with light X-carriage - Which motion system? September 16, 2020 11:17AM |
VDX
... pretty the same, as in your design, but 90deg turned belts is the "stone-old" buildup, used for flatbed-plotters and such
Have one in A3, which has NEMA17 steppers one for every axis (long rod with two pulleys for the two Y-belts).
[attachment 116708 XY-Plotter1.png] [attachment 116709 XY-Plotter2.png]
Re: Large machine with light X-carriage - Which motion system? September 16, 2020 12:32PM |
Re: Large machine with light X-carriage - Which motion system? September 16, 2020 02:53PM |
Re: Large machine with light X-carriage - Which motion system? September 26, 2020 09:43AM |
the_digital_dentist
I made a corexy mechanism that's 1.8m x 0.8 m using stacked 6 mm wide belts. It works well in the sand table. I had to make wide flanged pulleys using stacked ball bearings and printed flanges/tires to keep the belts on the pulleys. It originally used stepper motors but I kept running into the performance limits of the motors so I installed servomotors and now it's much better.
In the video you can see a wood cross brace at about the middle of the Y axis rails. That was needed because the belt tension was causing the Y axis rails (45 mm t-slot) to bow outward.
Re: Large machine with light X-carriage - Which motion system? September 26, 2020 08:42PM |
Re: Large machine with light X-carriage - Which motion system? October 04, 2020 05:42AM |
the_digital_dentist
The slots in the rails are the guides, and I used UHMW, and later PTFE blocks that fit in the slots for the bearings. You can see more here.
This is one of the Y axis bearing blocks- you can just see the white block of PTFE that fits into the slot in the frame rail, hiding behind the belts on the left.
The latest version of the bearing block design has one of the PTFE bearings spring loaded to prevent the whole X axis from shifting when the magnet carriage reverses direction in X. It increases friction a bit, but the servomotors don't mind. The whole thing runs a lot quieter when the X axis doesn't shift.
The belts may look a little off- that's because I put twists in the belts to ensure that the smooth backs of the belts would contact the pulleys instead of the teeth. I found the teeth were making a lot of zipping noises when the mechanism ran any faster than about 200 mm/sec. The twists are in the long belt runs between the drive pulleys on the motors and the corner pulley blocks. That long, straight belt run (almost 2 m) requires some minimum tension to ensure that the belt doesn't sag enough to contact the Y axis bearing block.
The magnet carriage slides on PTFE bearings that contact the black, square aluminum tube that serves as the X axis guide rail. By using square tubing there's no need for a second rail because the carriage can't rotate on the square tube.
This whole method of construction is a bit sloppy but it is more than adequate for a sand table that draws in a very forgiving medium. I don't think it would work well for a 3D printer unless you are very particular about print quality.
Re: Large machine with light X-carriage - Which motion system? October 04, 2020 09:52AM |
