Building a CoreXY : machined or printed parts ? December 03, 2022 01:14PM |
Re: Building a CoreXY : machined or printed parts ? December 03, 2022 07:22PM |
Re: Building a CoreXY : machined or printed parts ? December 04, 2022 10:50AM |
Re: Building a CoreXY : machined or printed parts ? December 04, 2022 11:15AM |
Re: Building a CoreXY : machined or printed parts ? December 05, 2022 10:07AM |
Re: Building a CoreXY : machined or printed parts ? December 05, 2022 01:37PM |
Re: Building a CoreXY : machined or printed parts ? December 05, 2022 02:13PM |
Re: Building a CoreXY : machined or printed parts ? December 06, 2022 01:08PM |
Re: Building a CoreXY : machined or printed parts ? December 06, 2022 01:26PM |
Re: Building a CoreXY : machined or printed parts ? December 06, 2022 02:14PM |
Re: Building a CoreXY : machined or printed parts ? December 07, 2022 01:51PM |
Re: Building a CoreXY : machined or printed parts ? December 07, 2022 04:22PM |
Re: Building a CoreXY : machined or printed parts ? December 09, 2022 07:17PM |
Re: Building a CoreXY : machined or printed parts ? December 09, 2022 08:11PM |
yet-another-average-joe
Yes indeed ; 2.5 or 5 mm pitch would make life easier with direst drive, having 0.1mm resolution would be great... Hope the Voron offers this resolution (didn't have look for now, next year project...).
For now, started with the Tornado rebuild. Cut some stock, inventored billets and sorted scrap aluminium. Had to re-CAD some parts depending on what is available in the basement, and requires the less metal removal.
Started with the stupid Y axis. 6 rollers. From factory, on one side, all 3 are adjustable (eccentric nuts). On the other side, all three are fixed.
All rollers and bearings were shot (see picture), grinding as hell, and were later replaced. The old rollers were in such a shape they couldn't be adjusted.
From factory : rollers #1, #2 and #3 fixed ; #4, #5 and #6 are adjustable (eccentric nuts) ; Since when 3 points could be aligned somewhere in the universe ??? As a result one roller was allways spinning free.
Long ago, I added an eccentric at #2 while I was replacing the rollers for the first time.
Today I made a 3.5mm thick backplate (#7), adding rigidity to the assembly, and cancelling or at least reducing wobble. And discovered the terrible precision of the holes positions (stamped) ! Finally got it to work properly, smooth as butter, all rollers gently touching the V grooves. Of course this requires double eccentrics for rollers #2, #4, #5 and #6. Replaced with flanged eccentrics of course, OpenBuilds knockoffs. Will soon make a tool combining two wrenches so double eccentrics will easily be adjustable in perfect sync.
[attachment 119937 20221209_225739-Copie.jpg]
Tomorrow, the motor mount + tensioner. Rigid, machined, unlike the factory flexible crap made of stamped 3mm alu sheet. Redesigned with a proper belt alignment (parallel, unlike the original design)
Re: Building a CoreXY : machined or printed parts ? December 10, 2022 11:04AM |
Re: Building a CoreXY : machined or printed parts ? December 15, 2022 06:41PM |
Re: Building a CoreXY : machined or printed parts ? December 15, 2022 10:48PM |
Re: Building a CoreXY : machined or printed parts ? December 15, 2022 11:47PM |
Re: Building a CoreXY : machined or printed parts ? December 16, 2022 01:09PM |
Re: Building a CoreXY : machined or printed parts ? December 16, 2022 06:03PM |
Re: Building a CoreXY : machined or printed parts ? December 17, 2022 05:47AM |
Do you remember the name of the video? I'd like to see thatQuote
The complicated one, that gives the best results, was demonstrated by Joe Pieckzinsky on his (amazing) YT channel. This extremely skilled toolmaker positioned the part vertically, attached to the table with a jig, and machined using the end of the tool. Needless to say he spent some time on tuning every detail ! He has an industrial CNC but did this operation on the Bridgeport. I didn't even consider attempting to do this !
Re: Building a CoreXY : machined or printed parts ? December 17, 2022 08:12PM |
Re: Building a CoreXY : machined or printed parts ? December 23, 2022 09:21PM |
Re: Building a CoreXY : machined or printed parts ? December 24, 2022 07:04PM |
Re: Building a CoreXY : machined or printed parts ? December 25, 2022 10:19AM |
Re: Building a CoreXY : machined or printed parts ? December 25, 2022 04:59PM |
Re: Building a CoreXY : machined or printed parts ? December 26, 2022 05:21PM |
Re: Building a CoreXY : machined or printed parts ? January 04, 2023 05:43PM |
Re: Building a CoreXY : machined or printed parts ? February 16, 2023 05:57PM |
Re: Building a CoreXY : machined or printed parts ? February 16, 2023 06:10PM |
