Teacup and Heater? November 06, 2011 05:16PM |
// name port pin pwm DEFINE_HEATER(extruder, PB3) //DEFINE_HEATER(bed, PB4) // DEFINE_HEATER(fan, PORTB, PINB4, OCR0 // DEFINE_HEATER(chamber, PORTD, PIND7, OCR2A) // DEFINE_HEATER(motor, PORTD, PIND6, OCR2
Re: Teacup and Heater? November 06, 2011 05:28PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Teacup and Heater? November 06, 2011 05:35PM |
Re: Teacup and Heater? November 06, 2011 05:41PM |
Re: Teacup and Heater? November 08, 2011 04:44PM |
Re: Teacup and Heater? November 08, 2011 05:20PM |
Re: Teacup and Heater? November 08, 2011 05:24PM |
Re: Teacup and Heater? November 08, 2011 05:38PM |
* 8. APPENDIX A - PWMABLE PINS AND MAPPINGS *
* list of PWM-able pins and corresponding timers *
* timer1 is used for step timing so don't use OC1A/OC1B * This is the one that makes me think you need to be careful
* they are omitted from this listing for that reason *
* For the atmega168/328, timer/pin mappings are as follows *
* OCR0A - PD6 - DIO6 *
* OCR0B - PD5 - DIO5 *
* OCR2A - PB3 - DIO11 *
* OCR2B - PD3 - DIO3 *
