Sprinter M190 (set bed temp and wait) not working
Posted by glyn
February 08, 2012 04:28PM
I have a Prusa, Sanguinololu, Sprinter set up.
If I fire up Pronterface and click on the set bed temp button then the SG circuit is activated and all works ok.
If I manually type in the gcode M190 S50 (or put that code in a file) then nothing happens.
Looking at the Sprinter source, M190 appears to be implemented, so what is my problem?
Re: Sprinter M190 (set bed temp and wait) not working
February 09, 2012 06:30AM
That is because there is no M190 command (See GCodes in the wiki)!
What you want is M140 S50!
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
February 09, 2012 06:42AM
It may not be documented in the wiki (this threw me at first) but the M190 code does exist, see code from sprinter.pde below.
Also if you google M190 you will find other references to it.
      case 190: // M190 - Wait bed for heater to reach target.
      #if TEMP_1_PIN > -1
        if (code_seen('S')) target_bed_raw = temp2analogh(code_value());
        codenum = millis();
        while(current_bed_raw < target_bed_raw) {
          if( (millis()-codenum) > 1000 ) //Print Temp Reading every 1 second while heating up.
            tt=analog2temp(current_raw);
            Serial.print("T:");
            Serial.print( tt );
            Serial.print(" B:");
            Serial.println( analog2temp(current_bed_raw) );
            codenum = millis();
            manage_heater();
      #endif
      break;
February 09, 2012 07:03AM
Then you should compare the code used for M190 to that implemented for M140!
Pronterface uses M140.
Bob Morrison
February 09, 2012 08:34AM
Good thinking..
Changing
To
if (code_seen('S')) target_bed_raw = temp2analogBed(code_value());
Seems to fix it.
I usually assume I am in error not the code.grinning smiley
February 09, 2012 11:49AM
Actually there is another change required to display the correct temperature so I have included all the code below.
While I was at it I also added some code for the M116 gcode so I can now set my start.gcode file in skeinforge to:
M140 S50 ; set bed temp
M104 S215 ; set extruder temp
M116 ; wait for both temps to be reached
Altered code in sprinter.pde
      #if TEMP_1_PIN > -1
        codenum = millis();
            Serial.print("T:");
            Serial.print( tt );
            Serial.println( analog2tempBed(current_bed_raw) );
            codenum = millis();
            manage_heater();
      #endif
      break;
      case 116: // M116 - Wait for bed & extruder to reach target.
        codenum = millis();
        while(current_bed_raw < target_bed_raw || current_raw < target_raw ) {
	            Serial.print("T:");
	            Serial.print( analog2temp(current_raw) );
	            codenum = millis();
            manage_heater();
      break;
February 09, 2012 04:44PM
Nice bit of coding M116 would be a useful addition.
On my machine because I have a high resistance bed it takes a time to heat up, so I don't really want my hot end waiting at working temperature for a long time whilst its not extruding as this may cause excessive heat build up in the insulator. It would be nice to avoid this, say wait until bed is 5 degrees below target then switch on the hot end. This way they both arrive at working temperature at about the same time.
This can be done with a few lines in the start code, but it would be nice with a single command implemented in firmware.
Say a command like
M116 S255 B110 D5 // Hot end to 255 , Bed to 110, switch on hot end when bed has 5 degrees to go.
Edited 1 time(s). Last edit at 02/09/2012 04:50PM by martinprice2004.
February 10, 2012 04:58AM
Yes it is probably a good idea to minimise the hot end standing time but I don't really think it is necessary to complicate the codes, what I have now used in my start.gcode file is the following.
M190 S40 ; set bed temp & wait
M140 S45 ; set bed to final temp
June 10, 2012 09:25PM
I added this to the wiki as it bit me too, when I changed my 10 Ohm thermistor to a 100 Ohm thermistor for the *hot end*:
Example: M190 S60
Please note that some versions of Sprinter firmware have a bug that is triggered if different resistances are chosen for the hot end and bed.
Once again, thanks for the help!
