Teacup incorrect response to M105 command
Posted by jbayless
February 18, 2012 11:25PM
My Teacup firmware has the following behaviour:
I send: M115
Teacup sends: ok FIRMWARE_NAME:Teacup FIRMWARE_URL:http%3A//github.com/triffid/Teacup_Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 TEMP_SENSOR_COUNT:1 HEATER_COUNT:1
I send: M105
Teacup ends: ok
T:317.75
Note that there is an endline between the "ok" and the "T:317.75". This is causing RepRap host to get confused, because the temperature should follow the ok on the same line.
Am I the first to observe this behaviour, or is it something anyone else has noticed?
Currently running: RAMPS 1.4 electronics
I'm just sending those commands directly over the Arduino serial monitor, but the same happens when I send them using RepRap host.
Re: Teacup incorrect response to M105 command
February 18, 2012 11:45PM
I've tracked this down in the code, and it looks like it was deliberately programmed for the case where REPRAP_HOST_COMPATIBILITY is less than 20110509. I guess the old RepRap Host software for some reason expected a newline there?
February 19, 2012 07:06AM
Yes, different hosts require different responses. Use Pronterface, which is satisfied with any response or adjust the response to what you need.
February 19, 2012 02:13PM
Ok, I've adjusted it to work with RepRap Host.
I may have now found another bug:
I say: G1 Y28.5 F3111.0
RepRap says: k
RepRap says: ook
ERROR: GCodeWriter.waitForResponse() - dud response from RepRap: k (hex: 6b20) [411.463s/32824ms]
ERROR: GCodeWriter.waitForResponse() - dud response from RepRap: ook (hex: 6f6f6b20) [411.463s/32824ms]
RepRap says: ok
It looks like there might be a typo somewhere?
Edited 1 time(s). Last edit at 02/19/2012 02:13PM by jbayless.
