Problems with Gen 6 Electronics March 12, 2013 02:43PM |
Re: Problems with Gen 6 Electronics March 13, 2013 03:31AM |
And did you UPLOAD the firmware to your controller after changing Config.H?Quote
km28104
I've tried making changes in Config.H, but see no effect
Well that is because the extruder does not have end stops.Quote
km28104
Extruder moves in both directions.
X, Y and Z use end stops so if they are not connected, connected wrong, or configured wrong in the firmware then you will only be able to move in one direction. You should be able to inverse the direction also in the firmware.Quote
km28104
Jogging in the plus direction on each axis moves axises towards the endstop - direction. Can't move them in the plus direction at all.
Re: Problems with Gen 6 Electronics March 14, 2013 07:46AM |
Re: Problems with Gen 6 Electronics March 14, 2013 08:23AM |
// Gen6 = 5 // Gen6 deluxe = 51 #ifndef MOTHERBOARD #define MOTHERBOARD 5 #endif
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to trueAny of the axis going the wrong way toggle the value, i.e. if true make false, if false make true.
/**************************************************************************************** * Gen6 pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 5 || MOTHERBOARD == 51 #define KNOWN_BOARD 1 #ifndef __AVR_ATmega644P__ #ifndef __AVR_ATmega1284P__ #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu. #endif #endif //x axis pins #define X_STEP_PIN 15 #define X_DIR_PIN 18 #define X_ENABLE_PIN 19 #define X_MIN_PIN 20 #define X_MAX_PIN -1 //y axis pins #define Y_STEP_PIN 23 #define Y_DIR_PIN 22 #define Y_ENABLE_PIN 24 #define Y_MIN_PIN 25 #define Y_MAX_PIN -1 //z axis pins #define Z_STEP_PIN 27 #define Z_DIR_PIN 28 #define Z_ENABLE_PIN 29 #define Z_MIN_PIN 30 #define Z_MAX_PIN -1 //extruder pins #define E0_STEP_PIN 4 //Edited @ EJE Electronics 20100715 #define E0_DIR_PIN 2 //Edited @ EJE Electronics 20100715 #define E0_ENABLE_PIN 3 //Added @ EJE Electronics 20100715 #define TEMP_0_PIN 5 //changed @ rkoeppl 20110410 #define TEMP_1_PIN -1 //changed @ rkoeppl 20110410 #define TEMP_2_PIN -1 //changed @ rkoeppl 20110410 #define HEATER_0_PIN 14 //changed @ rkoeppl 20110410 #define HEATER_1_PIN -1 #define HEATER_2_PIN -1 #if MOTHERBOARD == 5 #define HEATER_BED_PIN -1 //changed @ rkoeppl 20110410 #define TEMP_BED_PIN -1 //changed @ rkoeppl 20110410 #else #define HEATER_BED_PIN 1 //changed @ rkoeppl 20110410 #define TEMP_BED_PIN 0 //changed @ rkoeppl 20110410 #endif #define SDPOWER -1 #define SDSS 17 #define LED_PIN -1 //changed @ rkoeppl 20110410 #define FAN_PIN -1 //changed @ rkoeppl 20110410 #define PS_ON_PIN -1 //changed @ rkoeppl 20110410 //our pin for debugging. #define DEBUG_PIN 0 //our RS485 pins #define TX_ENABLE_PIN 12 #define RX_ENABLE_PIN 13 #endif
#define X_MIN_PIN 20 #define Y_MIN_PIN 25 #define Z_MIN_PIN 30
#define X_MIN_PIN -1 #define Y_MIN_PIN -1 #define Z_MIN_PIN -1
Re: Problems with Gen 6 Electronics March 15, 2013 08:28AM |
