Hello All,
Im new to this so bear with me.
I have a Makegear M2 with the Rambo Board and would like to use the Heat 1 MOSFET to power onboard LEDs.
I have some experience in Programming, VB specifically. I fired up Arduino and started poking around. Found a couple possible areas of interest.
1. Marlin_Main.h
2. Pins.h
I am assuming that the pin number relates to a physical pin location on the RAMBO board. for example, in PINS.h there is a line HEATER_1_PIN 7, is a reference to the location I may want to access.
In MARLIN_MAIN.h there is an area that may be of interest, (FAN_ON) secton using M code 106 & 108 to fire up the fans....
Now... can someone help connect the dots?
Thanks for any help in advance!
-Frank
Edited 1 time(s). Last edit at 11/07/2013 03:56PM by fmeroney.
