Y moves in the wrong direction, sometimes. December 10, 2014 12:29AM |
Re: Y moves in the wrong direction, sometimes. December 10, 2014 04:37AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Y moves in the wrong direction, sometimes. December 10, 2014 11:49AM |
#if MOTHERBOARD == 33 || MOTHERBOARD == 34 #define LARGE_FLASH true #define X_STEP_PIN 54 #define X_DIR_PIN 55 #define X_ENABLE_PIN 38 #define X_MIN_PIN 3 #define X_MAX_PIN -1 //Originalwer 2 - -1 damit er disabled wird #define Y_STEP_PIN 60 //Original 60 #define Y_DIR_PIN 61 //61 #define Y_ENABLE_PIN 56 //56 #define Y_MIN_PIN 14 //14 #define Y_MAX_PIN -1 //Original 15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 62 #define Z_MIN_PIN 18 #define Z_MAX_PIN -1 //Original 19 #define Z2_STEP_PIN 36 #define Z2_DIR_PIN 34 #define Z2_ENABLE_PIN 30 #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30 #define SDPOWER -1 #define SDSS 53 #define LED_PIN 13 #if MOTHERBOARD == 33 #define FAN_PIN 9 // (Sprinter config) #else #define FAN_PIN 4 // IO pin. Buffer needed #endif #define PS_ON_PIN 12 #if defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL) #define KILL_PIN 41 #else #define KILL_PIN -1 #endif #define HEATER_0_PIN 10 // EXTRUDER 1 #if MOTHERBOARD == 33 #define HEATER_1_PIN -1 #else #define HEATER_1_PIN 9 // EXTRUDER 2 (FAN On Sprinter) #endif #define HEATER_2_PIN -1 #define TEMP_0_PIN 13 // ANALOG NUMBERING #define TEMP_1_PIN 15 // ANALOG NUMBERING #define TEMP_2_PIN -1 // ANALOG NUMBERING #define HEATER_BED_PIN 8 // BED #define TEMP_BED_PIN 14 // ANALOG NUMBERING
Re: Y moves in the wrong direction, sometimes. December 12, 2014 10:31AM |
