Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 08, 2015 05:11PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 08, 2015 07:50PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 08, 2015 09:40PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 08, 2015 10:19PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 09, 2015 05:54PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 09, 2015 11:50PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 10, 2015 06:23AM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 10, 2015 01:02PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 10, 2015 04:02PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 10, 2015 05:42PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 10, 2015 09:04PM |
10:53:17.263 : OpenGL version:1.1.0 10:53:17.263 : OpenGL extensions:GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture 10:53:17.263 : OpenGL renderer:GDI Generic 10:53:17.263 : Fast VBOs for rendering not supported. Using slower default method. 10:53:25.968 : The port 'COM5' does not exist. 10:54:11.626 : Printer reset detected - initalizing 10:54:11.658 : start 10:54:11.658 : echo: Reset Esterno 10:54:11.658 : Marlin 1.0.0 10:54:11.658 : echo: Ultimo Aggiornamento: Apr 20 2015 18:14:04 | Autore: (none, default config) 10:54:11.658 : Compiled: Apr 20 2015 10:54:11.658 : echo: Memoria Libera: 4401 PlannerBufferBytes: 1232 10:54:11.658 : echo:Using Default settings: 10:54:11.658 : echoteps per unit: 10:54:11.658 : echo: M92 X64.25 Y64.25 Z2560.00 E600.00 10:54:11.658 : echo:Maximum feedrates (mm/s): 10:54:11.658 : echo: M203 X500.00 Y500.00 Z5.00 E500.00 10:54:11.658 : echo:Maximum Acceleration (mm/s2): 10:54:11.658 : echo: M201 X9000 Y9000 Z100 E10000 10:54:11.658 : echo:Acceleration: S=acceleration, T=retract acceleration 10:54:11.658 : echo: M204 S1000.00 T1000.00 10:54:11.658 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) 10:54:11.658 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 10:54:11.658 : echo:Home offset (mm): 10:54:11.658 : echo: M206 X0.00 Y0.00 Z0.00 10:54:11.658 : echoID settings: 10:54:11.658 : echo: M301 P63.00 I2.25 D440.00 10:54:12.188 : N1 M110 *2 10:54:12.188 : N2 M115 *4 10:54:12.266 : N3 M105 *4 10:54:12.812 : N4 M111 S6 *67 10:54:12.843 : N5 T0 *31 10:54:12.843 : N6 M20 *55 10:54:12.843 : N7 M80 *60 10:54:14.060 : echo:Fallita Inizializzazione SD 10:54:14.091 : echo:Comando sconosciuto: "" 10:54:14.091 : ok 10:54:14.107 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 0 10:54:14.107 : Reinviato:1 10:54:14.107 : ok 10:54:15.324 : N8 M105 *15 10:54:15.324 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 0 10:54:15.324 : Reinviato:1 10:54:15.324 : ok 10:54:15.433 : N1 M110 *2 10:54:15.433 : N2 M115 *4 10:54:15.433 : N3 M111 S6 *68 10:54:15.433 : N4 T0 *30 10:54:15.433 : N5 M20 *52 10:54:15.433 : ok 10:54:15.433 : N6 M80 *61 10:54:15.433 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[reprap.org] PROTOCOL_VERSION:1.0 MACHINE_TYPE:RepRap EXTRUDER_COUNT:1 10:54:15.433 : ok 10:54:15.433 : ok 10:54:15.433 : N7 M220 S100 *70 10:54:15.433 : echo:Attiva Estrusore: 0 10:54:15.433 : ok 10:54:15.433 : Inizio Lista File 10:54:15.433 : N8 M221 S100 *72 10:54:15.433 : Fine Lista File 10:54:15.433 : ok 10:54:15.433 : ok 10:54:15.433 : N9 M111 S6 *78 10:54:15.433 : N10 T0 *43 10:54:15.448 : echo:Comando sconosciuto: " File" 10:54:15.448 : ok 10:54:15.448 : Error:Nessun Numero di Linea con Checksum, Ultima Linea: 6 10:54:15.448 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:15.448 : Reinviato:7 10:54:15.448 : ok 10:54:18.381 : N11 M105 *55 10:54:18.381 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:18.381 : Reinviato:7 10:54:18.381 : ok 10:54:21.439 : N12 M105 *52 10:54:21.439 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:21.439 : Reinviato:7 10:54:21.439 : ok 10:54:24.497 : N13 M105 *53 10:54:24.497 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:24.497 : Reinviato:7 10:54:24.497 : ok 10:54:27.554 : N14 M105 *50 10:54:27.554 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:27.554 : Reinviato:7 10:54:27.554 : ok 10:54:30.612 : N15 M105 *51 10:54:30.612 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:30.612 : Reinviato:7 10:54:30.612 : ok 10:54:33.670 : N16 M105 *48 10:54:33.670 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:33.670 : Reinviato:7 10:54:33.670 : ok 10:54:36.729 : N17 M105 *49 10:54:36.729 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:36.729 : Reinviato:7 10:54:36.729 : ok 10:54:39.789 : N18 M105 *62 10:54:39.789 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:39.789 : Reinviato:7 10:54:39.789 : ok 10:54:42.847 : N19 M105 *63 10:54:42.847 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:42.847 : Reinviato:7 10:54:42.847 : ok 10:54:45.905 : N20 M105 *53 10:54:45.905 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:45.905 : Reinviato:7 10:54:45.905 : ok 10:54:48.963 : N21 M105 *52 10:54:48.963 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:48.963 : Reinviato:7 10:54:48.963 : ok 10:54:52.022 : N22 M105 *55 10:54:52.022 : Error:Il Numero della Linea non corrisponde al Numero dell'Ultima Linea+1, Ultima Linea: 6 10:54:52.022 : Reinviato:7 10:54:52.022 : ok
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 10, 2015 09:45PM |
11:42:05.152 : OpenGL version:1.1.0 11:42:05.154 : OpenGL extensions:GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture 11:42:05.154 : OpenGL renderer:GDI Generic 11:42:05.154 : Fast VBOs for rendering not supported. Using slower default method. 11:42:21.454 : N1 M110 *2 11:42:21.454 : N2 M115 *4 11:42:21.454 : N3 M105 *4 11:42:21.454 : N4 M114 *3 11:42:21.454 : N5 M111 S6 *66 11:42:21.456 : N6 T0 *28 11:42:21.456 : N7 M20 *54 11:42:21.458 : N8 M80 *51 11:42:21.500 : N9 M105 *14 11:42:24.555 : N10 M105 *54
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 11, 2015 02:48AM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 11, 2015 03:08AM |
o_lampe
It seems the previous owner has changed the board and wired the printer to it in his own way.
We´d need pictures and details as much as possible to help you out.
eg.
How many endstops, where are they?
Steppers, belts, pulleys, leadscrews, extruder-gear etc.
Then we could guide you through a rewire-process and configuration to match common sense.
-Olaf
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 12, 2015 02:37PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 13, 2015 06:23AM |
RGN01
You may already know this but if stepper motor direction of rotation is wrong, simply change the plugs into the RAMPS over (top to bottom) and rotation will reverse.
HTH
Richard
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 13, 2015 01:14PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 14, 2015 04:48AM |
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
#define DEFAULT_AXIS_STEPS_PER_UNIT {160.0,160.0, 8000.0, 185.0} // for drv8825 and M5 #define DEFAULT_MAX_FEEDRATE {450, 450, 3, 25} // (mm/sec)
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 17, 2015 12:38PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 18, 2015 09:48PM |
o_lampe
Better look for this section and modify x and also move the x-endstop connector on the board to act as a "max"-endstop and "max" homing direction.
Regarding the z-motor: Check the Vref of the z-driver. Did you set the z-steps to match the lead screw? The default values are for M5 ( 0.8mm/turn )
They won´t work for the much steeper lead screw. Also reduce z-max feedrate until it runs smooth ( start with "1" )
-Olaf
THAT is exactly how I feel! I'm sure it's just all about tweaking the firmware to get it going. I just don't have the skills to do it without guidance. I was actually hoping someone would say "yeah, I have a K8200 with Mega/RAMPS on it - let me post my firmware for you" - I guess that was wishful thinking...Quote
ntoff
If it was working before hand, I wouldn't touch the hardware at all, don't flip the plugs, don't fiddle with the voltage pots on the drivers (you can damage them if you don't know what you're doing). Obviously it was working before with that hardware configuration.
Yes I do have an LCD/SD unit. I can get the LCD working by selecting 'Smartcontroller from RepRapDiscount on a RAMPS or RUMBA board' when I configure the Repetier Firmware.Quote
ntoff
That looks like it might have a full graphic LCD panel on it? From that adapter thing up top of the RAMPS board. Yes?
I really don't give a hoot about which firmware I have running on the thing - I just want the printer working again! I'm at Kallangur (30km north of Brisbane).Quote
ntoff
I don't know how the repetier firmware works but if you want help with Marlin I might be able to do so. Also where are you? I'm also in Aus (brisbane area)
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 18, 2015 09:59PM |
dislegal
My Y axis homing stops when it hits the end stop and slowly moves back a little then into place (as it should). My X axis homing now hits the end stop and jumps/smashes for a little bit.
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 18, 2015 10:18PM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 18, 2015 11:28PM |
epr pos="75" type="2" value="250000">Baudrate epr pos="129" type="3" value="-0.111">Filament printed epr pos="125" type="2" value="1197">Printer active epr pos="79" type="2" value="0">Max. inactive time epr pos="83" type="2" value="360000">Stop stepper after inactivity epr pos="3" type="3" value="80.0000">X-axis steps per mm epr pos="7" type="3" value="80.0000">Y-axis steps per mm epr pos="11" type="3" value="80.0000">Z-axis steps per mm epr pos="15" type="3" value="200.000">X-axis max. feedrate epr pos="19" type="3" value="200.000">Y-axis max. feedrate epr pos="23" type="3" value="3.000">Z-axis max. feedrate epr pos="27" type="3" value="40.000">X-axis homing feedrate epr pos="31" type="3" value="40.000">Y-axis homing feedrate epr pos="35" type="3" value="2.000">Z-axis homing feedrate epr pos="39" type="3" value="20.000">Max. jerk epr pos="47" type="3" value="0.300">Max. Z-jerk epr pos="133" type="3" value="0.000">X min pos epr pos="137" type="3" value="0.000">Y min pos epr pos="141" type="3" value="0.000">Z min pos epr pos="145" type="3" value="200.000">X max length epr pos="149" type="3" value="200.000">Y max length epr pos="153" type="3" value="200.000">Z max length epr pos="51" type="3" value="1000.000">X-axis acceleration epr pos="55" type="3" value="1000.000">Y-axis acceleration epr pos="59" type="3" value="50.000">Z-axis acceleration epr pos="63" type="3" value="1000.000">X-axis travel acceleration epr pos="67" type="3" value="1000.000">Y-axis travel acceleration epr pos="71" type="3" value="50.000">Z-axis travel acceleration epr pos="880" type="0" value="0">Autolevel active (1/0) epr pos="106" type="0" value="0">Bed Heat Manager epr pos="107" type="0" value="255">Bed PID drive max epr pos="124" type="0" value="80">Bed PID drive min epr pos="108" type="3" value="196.000">Bed PID P-gain epr pos="112" type="3" value="33.000">Bed PID I-gain epr pos="116" type="3" value="290.000">Bed PID D-gain epr pos="120" type="0" value="255">Bed PID max value epr pos="1020" type="0" value="0">Enable retraction conversion epr pos="992" type="3" value="3.000">Retraction length epr pos="1000" type="3" value="40.000">Retraction speed epr pos="1004" type="3" value="0.000">Retraction z-lift epr pos="1008" type="3" value="0.000">Extra extrusion on undo retract epr pos="1016" type="3" value="20.000">Retraction undo speed epr pos="200" type="3" value="370.000">Extr.1 steps per mm epr pos="204" type="3" value="50.000">Extr.1 max. feedrate epr pos="208" type="3" value="20.000">Extr.1 start feedrate epr pos="212" type="3" value="5000.000">Extr.1 acceleration epr pos="216" type="0" value="3">Extr.1 heat manager epr pos="217" type="0" value="230">Extr.1 PID drive max epr pos="245" type="0" value="40">Extr.1 PID drive min epr pos="218" type="3" value="7.0000">Extr.1 PID P-gain/dead-time epr pos="222" type="3" value="2.0000">Extr.1 PID I-gain epr pos="226" type="3" value="40.0000">Extr.1 PID D-gain epr pos="230" type="0" value="255">Extr.1 PID max value epr pos="231" type="2" value="0">Extr.1 X-offset epr pos="235" type="2" value="0">Extr.1 Y-offset epr pos="290" type="2" value="0">Extr.1 Z-offset epr pos="239" type="1" value="1">Extr.1 temp. stabilize time epr pos="250" type="1" value="150">Extr.1 temp. for retraction when heating epr pos="252" type="1" value="0">Extr.1 distance to retract when heating epr pos="254" type="0" value="255">Extr.1 extruder cooler speed
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 19, 2015 04:48AM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 20, 2015 03:30AM |
I actually have the Marlin firmware from when I had the RAMPS on the k8200 before I turned it into the frankenprinter but it uses the same pins for the LCD that the 3drag board used and is only a 16 x 4 LCD. I've messed about with it so much that I wouldn't feel confident throwing you into the deep end trying to figure out what I've done to it.Quote
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 27, 2015 04:02AM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 27, 2015 05:45AM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 27, 2015 05:49AM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 27, 2015 05:50AM |
Re: Post subject: @$%&*#! Nearly ready to throw the printer out the window! July 27, 2015 07:35AM |
