I am having workflow problems with the web interface that I guess I don't fully understand.
slic3r inserts the following code into the gcode file:
M190 S40 ; set bed temperature
M104 S210 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
M109 S210 ; wait for temperature to be reached
I find I have to increase my Active temps to near the 210 and 40 before the print will start.
I will have my temps pre-heated to maybe 190 and 55 for the AutoBed compensation, but have to increase the extruder temp to get things moving.
What is the relationship between Active temps and Standby temps?
How should I be using them to preheat for compensation, and then be able to run a print without having to manually adjust the temps?
TIA,
Rick
