Marlin compilation failure
Posted by Jbro824
October 06, 2015 12:34AM
ok so i am new to marlin and the RAMBo board and i can not get marlin to compile without this message
Arduino: 1.6.4 (Windows 7), Board: "RAMBo"
Build options changed, rebuilding all
Using library Marlin in folder: C:\Users\Jed\Documents\Arduino\libraries\Marlin (legacy)
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library U8glib in folder: C:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib (legacy)
Using library LiquidCrystal in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\blinkm.cpp -o C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\blinkm.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\cardreader.cpp -o C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\cardreader.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\ConfigurationStore.cpp -o C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\ConfigurationStore.cpp.o
C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\ConfigurationStore.cpp: In function 'void Config_ResetDefault()':
C:\Users\Jed\AppData\Local\Temp\build5011499210331873017.tmp\ConfigurationStore.cpp:238:3: error: 'add_homeing' was not declared in this scope
add_homeing[0] = add_homeing[1] = add_homeing[2] = 0;
Error compiling.
please help
Re: Marlin compilation failure
October 06, 2015 04:02AM
Jbro824
Error compiling.
Which version of Marlin are you using? I don't use RAMBO, but the variable add_homeing looks rather old, it was used in Marlin 1.0.0, in Marlin 1.0.2 it was changed to add_homing, and in 1.0.3 it's called home_offset...
So, could it be that you have some mixup of several installed versions of Marlin on your system? (I see that you have a Marlin directory in Arduino\libraries\Marlin, is that the version you are compiling?)
October 06, 2015 07:30AM
I have no idea what version of marlin i am using but the one i downloaded was supposed to have been set up for my printer by someone else so i was trying to be simple but as you can see that did not work
where can i get a current version of marlin?
Thanks
October 06, 2015 09:44AM
You can download the official version(s) from here. But I suggest that you also look at the Wiki.
October 06, 2015 10:53PM
ok thanks to enif i solved my first problem but now when compiling it works for a while then stops what do i do now?
October 07, 2015 12:17AM
Jbro824
... what do i do now?
How about explaining in detail when and how it "stops"?
October 07, 2015 09:27PM
well it goes and goes and then stops this is the log
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\BlinkM.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\BlinkM.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\cardreader.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\cardreader.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\ConfigurationStore.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\ConfigurationStore.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\digipot_mcp4451.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\digipot_mcp4451.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\LiquidCrystalRus.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\LiquidCrystalRus.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\MarlinSerial.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\MarlinSerial.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin_main.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin_main.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\motion_control.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\motion_control.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\planner.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\planner.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\qr_solve.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\qr_solve.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Sd2Card.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Sd2Card.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdBaseFile.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdBaseFile.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdFatUtil.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdFatUtil.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdFile.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdFile.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdVolume.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdVolume.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Servo.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Servo.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\stepper.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\stepper.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\temperature.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\temperature.cpp.o
C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\temperature.cpp:565:46: warning: extra tokens at end of #ifdef directive [enabled by default]
#ifdef THERMAL_RUNAWAY_PROTECTION_PERIOD && THERMAL_RUNAWAY_PROTECTION_PERIOD > 0
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\ultralcd.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\ultralcd.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\vector_3.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\vector_3.cpp.o
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_RAMBO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\variants\rambo -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Users\Jed\AppData\Roaming\Arduino15\packages\rambo\hardware\avr\1.0.0\libraries\U8glib -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\watchdog.cpp -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\watchdog.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\BlinkM.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\cardreader.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\ConfigurationStore.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\digipot_mcp4451.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\LiquidCrystalRus.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\MarlinSerial.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\Marlin_main.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\motion_control.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\planner.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\qr_solve.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\Sd2Card.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdBaseFile.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdFatUtil.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdFile.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdVolume.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\Servo.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\stepper.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\temperature.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\ultralcd.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\vector_3.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\watchdog.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Wire\utility\twi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\U8glib.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\chessengine.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_bitmap.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_circle.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_clip.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_api.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_api_16gr.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_common.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_fast_parallel.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_hw_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_no_en_parallel.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_parallel.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_port_d_wr.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_ssd_i2c.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_st7920_hw_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_st7920_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_std_sw_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_sw_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_t6963.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_hw_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_parallel.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_st7920_hw_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_st7920_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_sw_spi.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_i2c.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_io.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_null.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_cursor.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_delay.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_flipdisc_2x7.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_gprof.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ili9325d_320x240.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ks0108_128x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_160x80.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_240x128.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_240x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_320x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_null.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_pcd8544_84x48.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_pcf8812_96x65.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_sbn1661_122x32.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1306_128x32.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1306_128x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1309_128x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1322_nhd31oled_bw.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1322_nhd31oled_gr.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_bw.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_bw_new.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_gr.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_gr_new.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1327_96x96_gr.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_64128n.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_dogm128.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_dogm132.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_lm6059.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_lm6063.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_nhd_c12832.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_nhd_c12864.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7687_c144mvgd.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7920_128x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7920_192x32.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7920_202x32.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_t6963_128x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_t6963_240x128.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_t6963_240x64.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_tls8204_84x48.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_uc1610_dogxl160.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_uc1701_dogs102.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_uc1701_mini12864.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_ellipse.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_font.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_font_data.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_line.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_ll_api.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_page.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb14v1.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16h1.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16h2.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16v1.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16v2.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb32h1.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h1.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h1f.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h2.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h8.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8v1.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8v2.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_rect.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_rot.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_scale.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_state.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_u16toa.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_u8toa.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_virtual_screen.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\LiquidCrystal\LiquidCrystal.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SPI\SPI.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\hooks.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\WInterrupts.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\wiring.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\wiring_analog.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\wiring_digital.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\wiring_pulse.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\wiring_shift.c.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\abi.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\CDC.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\HID.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\IPAddress.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\main.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\new.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Print.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Stream.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Tone.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\USBCore.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\WMath.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\WString.cpp.o
Using previously compiled file: C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\core.a
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc -Os -Wl,--gc-sections,--relax -mmcu=atmega2560 -o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp/Marlin.cpp.elf C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\BlinkM.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\cardreader.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\ConfigurationStore.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\digipot_mcp4451.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\LiquidCrystalRus.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\MarlinSerial.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin_main.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\motion_control.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\planner.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\qr_solve.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Sd2Card.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdBaseFile.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdFatUtil.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdFile.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SdVolume.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Servo.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\stepper.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\temperature.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\ultralcd.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\vector_3.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\watchdog.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\BlinkM.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\cardreader.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\ConfigurationStore.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\digipot_mcp4451.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\LiquidCrystalRus.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\MarlinSerial.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\Marlin_main.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\motion_control.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\planner.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\qr_solve.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\Sd2Card.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdBaseFile.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdFatUtil.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdFile.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\SdVolume.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\Servo.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\stepper.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\temperature.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\ultralcd.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\vector_3.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Marlin\watchdog.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Wire\Wire.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\Wire\utility\twi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\U8glib.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\chessengine.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_bitmap.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_circle.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_clip.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_api.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_api_16gr.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_common.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_fast_parallel.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_hw_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_no_en_parallel.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_parallel.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_port_d_wr.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_ssd_i2c.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_st7920_hw_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_st7920_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_std_sw_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_sw_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_arduino_t6963.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_hw_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_parallel.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_st7920_hw_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_st7920_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_atmega_sw_spi.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_i2c.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_io.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_com_null.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_cursor.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_delay.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_flipdisc_2x7.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_gprof.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ili9325d_320x240.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ks0108_128x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_160x80.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_240x128.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_240x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_lc7981_320x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_null.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_pcd8544_84x48.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_pcf8812_96x65.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_sbn1661_122x32.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1306_128x32.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1306_128x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1309_128x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1322_nhd31oled_bw.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1322_nhd31oled_gr.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_bw.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_bw_new.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_gr.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_gr_new.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_ssd1327_96x96_gr.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_64128n.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_dogm128.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_dogm132.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_lm6059.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_lm6063.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_nhd_c12832.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7565_nhd_c12864.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7687_c144mvgd.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7920_128x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7920_192x32.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_st7920_202x32.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_t6963_128x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_t6963_240x128.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_t6963_240x64.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_tls8204_84x48.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_uc1610_dogxl160.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_uc1701_dogs102.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_dev_uc1701_mini12864.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_ellipse.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_font.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_font_data.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_line.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_ll_api.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_page.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb14v1.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16h1.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16h2.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16v1.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb16v2.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb32h1.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h1.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h1f.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h2.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8h8.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8v1.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_pb8v2.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_rect.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_rot.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_scale.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_state.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_u16toa.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_u8toa.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\U8glib\utility\u8g_virtual_screen.c.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\LiquidCrystal\LiquidCrystal.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp\SPI\SPI.cpp.o C:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp/core.a -LC:\Users\Jed\AppData\Local\Temp\build2208159704791052872.tmp -lm
October 08, 2015 01:28AM
And where is the compilation error/falure now? I don't see any. Please explain what the actual problem is.
October 08, 2015 01:37AM
the lack of an error is the problem. it gets to there and just stops
October 08, 2015 06:17AM
I've got also sometimes issues like that. Use a newer or older version of Arduino. Some don't show any errors and starts to hang.
October 08, 2015 11:38PM
ok tanks to every one for their help
i tried updating to arduino ide 1.6.5 but now i end up with this
Arduino: 1.6.5 (Windows 7), Board: "RAMBo"
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `Stopped'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin_main.cpp.o:C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp/Marlin_main.cpp:1358: first defined here
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin\Marlin_main.cpp.o: In function `pgm_read_any':
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `manage_inactivity(bool)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `Stop()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `IsStopped()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `setTargetedHotend(int)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `calculate_volumetric_multiplier(float)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `volumetric_enabled'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `calculate_volumetric_multipliers()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `filament_size'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `volumetric_multiplier'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `process_commands()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `saved_feedmultiply'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `fanSpeed'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `stoptime'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `starttime'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `CooldownNoWait'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `target_direction'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `cancel_heatup'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `extruder_multiply'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `extrudemultiply'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `zprobe_zoffset'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/Marlin_main.cpp:1358: multiple definition of `loop'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin\motion_control.cpp.o: In function `mc_arc(float*, float*, float*, unsigned char, unsigned char, unsigned char, float, float, unsigned char, unsigned char)':
C:\Users\Jed\Documents\Arduino\libraries\Marlin/motion_control.cpp:30: multiple definition of `mc_arc(float*, float*, float*, unsigned char, unsigned char, unsigned char, float, float, unsigned char, unsigned char)'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\motion_control.cpp.o:C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp/motion_control.cpp:30: first defined here
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin\planner.cpp.o: In function `calculate_trapezoid_for_block(block_t*, float, float)':
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `calculate_trapezoid_for_block(block_t*, float, float)'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\planner.cpp.o:C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp/planner.cpp:181: first defined here
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `planner_reverse_pass_kernel(block_t*, block_t*, block_t*)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `planner_reverse_pass()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `block_buffer_head'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `block_buffer_tail'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `block_buffer'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `planner_forward_pass_kernel(block_t*, block_t*, block_t*)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `planner_forward_pass()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `planner_recalculate_trapezoids()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `planner_recalculate()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `plan_init()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `position'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `getHighESpeed()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `autotemp_enabled'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `autotemp_min'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `autotemp_factor'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `autotemp_max'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `check_axes_activity()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `plan_buffer_line(float const&, float const&, float const&, float const&, float, unsigned char const&)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `axis_steps_per_unit'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `extrude_min_temp'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `g_uc_extruder_last_move'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `mintravelfeedrate'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `minimumfeedrate'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `minsegmenttime'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `max_feedrate'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `retract_acceleration'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `acceleration'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `axis_steps_per_sqr_second'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `max_xy_jerk'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `max_z_jerk'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `max_e_jerk'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `plan_set_position(float const&, float const&, float const&, float const&)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `plan_set_e_position(float const&)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `movesplanned()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `set_extrude_min_temp(float)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `reset_acceleration_rates()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `max_acceleration_units_per_sq_second'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/planner.cpp:181: multiple definition of `junction_deviation'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin\stepper.cpp.o: In function `checkHitEndstops()':
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `checkHitEndstops()'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\stepper.cpp.o:C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp/stepper.cpp:175: first defined here
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `endstops_trigsteps'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `endstops_hit_on_purpose()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `enable_endstops(bool)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `st_wake_up()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `step_wait()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `__vector_17'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `current_block'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `count_direction'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `count_position'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `st_init()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `st_synchronize()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `st_set_position(long const&, long const&, long const&, long const&)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `st_set_e_position(long const&)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `st_get_position(unsigned char)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `finishAndDisableSteppers()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `quickStop()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `digitalPotWrite(int, int)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `digipot_init()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `digipot_current(unsigned char, int)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `microstep_init()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `microstep_ms(unsigned char, signed char, signed char)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `microstep_mode(unsigned char, unsigned char)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `microstep_readings()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `endstops_stepsDone'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/stepper.cpp:175: multiple definition of `endstops_stepsTotal'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin\temperature.cpp.osad smiley.bss.current_temperature_raw+0x0): multiple definition of `current_temperature_raw'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\temperature.cpp.osad smiley.bss.current_temperature_raw+0x0): first defined here
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin\temperature.cpp.o: In function `analog2tempBed':
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `current_temperature'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\temperature.cpp.o:C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp/temperature.cpp:175: first defined here
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `current_temperature_bed_raw'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `current_temperature_bed'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `updatePID()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `Ki'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `getHeaterPower(int)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `soft_pwm_bed'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `manage_heater()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `target_temperature'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `Kp'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `Kd'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `target_temperature_bed'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `tp_init()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `setWatch()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `disable_heater()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `PID_autotune(float, int, int)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `max_temp_error(unsigned char)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `min_temp_error(unsigned char)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `bed_max_temp_error()'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `__vector_22'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `scalePID_i(float)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `unscalePID_i(float)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `scalePID_d(float)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `unscalePID_d(float)'
C:\Users\Jed\Documents\Arduino\libraries\Marlin/temperature.cpp:175: multiple definition of `Kc'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\Marlin\watchdog.cpp.o: In function `watchdog_init()':
C:\Users\Jed\Documents\Arduino\libraries\Marlin/watchdog.cpp:28: multiple definition of `watchdog_init()'
C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp\watchdog.cpp.o:C:\Users\Jed\AppData\Local\Temp\build4745252936631248038.tmp/watchdog.cpp:28: first defined here
C:\Users\Jed\Documents\Arduino\libraries\Marlin/watchdog.cpp:28: multiple definition of `watchdog_reset()'
collect2.exe: error: ld returned 1 exit status
Error compiling.
i am going to try 1.6.4 again and 1.6.3 as well
Re: Marlin compilation failure
October 09, 2015 01:28AM
Hi jbhro,
This might help a bit. I was having an error compiling Marlin on the laptop which had me banging the wall.
The library at fault was u8glib. What had happened was library had been partially copied to
\user\...\arduino\libraries
as well as properly to
\program....\.....\arduino\libraries
I have no idea why this was but as soon as I deleted \user\...etc library directory everything worked.
Why there was 2 library directories I don't know.
Andrew
October 09, 2015 12:13PM
ok so ive thriedother versions and they just turn up errors miles long so back to 1.6.4 and now it does this and lags out so it never finishes
Using library Marlin in folder: C:\Users\Jed\Documents\Arduino\libraries\Marlin (legacy)
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library LiquidCrystal in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_YUN -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8041 -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Yun" -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\yun -IC:\Users\Jed\Documents\Arduino\libraries\Marlin -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI C:\Users\Jed\AppData\Local\Temp\build67328903109902864.tmp\BlinkM.cpp -o C:\Users\Jed\AppData\Local\Temp\build67328903109902864.tmp\BlinkM.cpp.o
October 09, 2015 12:21PM
Why is your Marlin in /libraries/?
October 09, 2015 12:27PM
it is here so when i was redoing my aduino ide installation on a regular basis it would not be deleted and it is also where it was installed by arduino and i never moved it. should it be somewhere else?
November 04, 2015 11:31AM
ok so over the past little while despite the help from everyone marlin never did work. so in light of that i tried using repitier instead and it works well. now the problem is that my z axis does not work. it just starts to twitch and whine for the amount of time it is supposed to run for then quits. it never moves the gantry up or down at all any suggestions?
November 08, 2015 09:34AM
Increase the driver voltage.
