Hello guys,
I am using a Prusa I3 Single Nozzle Printer with an Ramps 1.4 (Prusa MK 2S clone).
The firmware I am using is the Prusa I3 Mk 2S Ver 3.1.0 optimized from Slippyr4:
Slippyr4 Github
I added a thermistor on my board on Pin 15 -> Temp_1_PIN.
The thermistor is connected to the internals of my power supply. I want to read the power supply temperature, if the temp is higher than a treshold it should shutoff.
The problem is, I dont know how to add the thermisor in the firmware. I already set the extruders to 2:
// This defines the number of extruders
#define EXTRUDERS 2
to activate the second thermistor. Then I modified the:
ultralcd_implementation_hitachi_HD44780.h
and added
int tHotend=int(degHotend(0) + 0.5);
int tTarget=int(degTargetHotend(0) + 0.5);
//Print the hotend temperature 1
lcd.setCursor(0, 0);
lcd.print(LCD_STR_THERMOMETER[0]);
lcd.print(itostr3(tHotend));
lcd.print('/');
lcd.print(itostr3left(tTarget));
lcd_printPGM(PSTR(LCD_STR_DEGREE " "));
lcd_printPGM(PSTR(" "));
################## here begins the addeded content #################
tHotend=int(degHotend(1) + 0.5);
tTarget=int(degTargetHotend(1) + 0.5);
//Print the hotend temperature 2
lcd.setCursor(0, 1);
lcd.print('/');
############### end of my added content #####################
//Print the Z coordinates
lcd.setCursor(LCD_WIDTH - 8-2, 1);
#if 1
lcd_printPGM(PSTR(" Z"));
if (custom_message_type == 1) {
// In a bed calibration mode.
lcd_printPGM(PSTR(" --- "));
} else {
lcd.print(ftostr32sp(current_position[Z_AXIS] + 0.00001));
lcd.print(' ');
#else
lcd_printPGM(PSTR(" Queue:"));
lcd.print(int(moves_planned()));
lcd.print(' ');
#endif
//Print the Bedtemperature
lcd.setCursor(LCD_WIDTH - 8-2, 0);
tHotend=int(degBed() + 0.5);
tTarget=int(degTargetBed() + 0.5);
lcd.print(LCD_STR_BEDTEMP[0]);
lcd.print('/');
I also double chekd that the pins in pins.h are mapped the right way to Pin 15.
If I compile the firmware like this it will be shown on my printer like this (See attached picture):
(LCD Layout was modified from me)
It will show the 2 thermistors in the display but the 2 thermistor is somehow mapped to the Bed thermistor .... (Hotend 1 thermistor is not defined as redundant! in the setting). So something is wrong with the definitions I think.
should activate the 2 Thermistor .... but it is the Bed thermistor so the Bed thermistor is shown twice in my display.
Anyone an idea what I am missing ?
Edited 5 time(s). Last edit at 02/13/2018 04:04AM by Foxen.
open |
download -
(156.5 KB)
