Marlin M109 gcode woes October 10, 2012 03:01AM |
Re: Marlin M109 gcode woes October 10, 2012 06:08AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Marlin M109 gcode woes October 10, 2012 04:59PM |
Re: Marlin M109 gcode woes October 10, 2012 07:02PM |
; generated by Slic3r 0.9.3 on 2012-10-11 at 11:47:48 ; layer_height = 0.3 ; perimeters = 3 ; solid_layers = 3 ; fill_density = 0.4 ; perimeter_speed = 30 ; infill_speed = 60 ; travel_speed = 130 ; scale = 1 ; nozzle_diameter = 0.4 ; filament_diameter = 2.9 ; extrusion_multiplier = 1 ; single wall width = 0.42mm M104 S170 ; set temperature <- works G28 ; home all axes <- works M109 S170 ; wait for temperature to be reached <- Extruder heater turns off G90 ; use absolute coordinates G21 ; set units to millimeters G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000 G92 E0 G1 Z0.200 F7800.000 G1 X92.900 Y81.028
case 109:
{// M109 - Wait for extruder heater to reach target.
tmp_extruder = active_extruder;
if(code_seen('T')) {
tmp_extruder = code_value();
if(tmp_extruder >= EXTRUDERS) {
SERIAL_ECHO_START;
SERIAL_ECHO(MSG_M109_INVALID_EXTRUDER);
SERIAL_ECHOLN(tmp_extruder);
break;
case 104: // M104
SERIAL_ECHO_START;
SERIAL_ECHO(MSG_M104_INVALID_EXTRUDER);
break;
Re: Marlin M109 gcode woes October 11, 2012 07:03AM |
Re: Marlin M109 gcode woes October 11, 2012 04:18PM |
Re: Marlin M109 gcode woes October 12, 2012 04:19AM |
Re: Marlin M109 gcode woes October 12, 2012 07:25AM |
NOT gcode driven but rather using PronterFace to extrude plastic.
Re: Marlin M109 gcode woes October 13, 2012 03:23AM |
