MARLIN: M42 November 26, 2012 07:53AM |
Re: MARLIN: M42 November 26, 2012 10:46AM |
Re: MARLIN: M42 November 26, 2012 11:16AM |
Re: MARLIN: M42 November 26, 2012 12:56PM |
Re: MARLIN: M42 November 27, 2012 07:32AM |
the "analog" pins are the same as PWM
Bear in mind, you can't power things like fans, heaters, or even a bank of LEDs directly from the Arduino.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: MARLIN: M42 December 15, 2012 01:47AM |
Re: MARLIN: M42 December 15, 2012 07:00AM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: MARLIN: M42 December 19, 2012 05:10PM |
One LED, not a bank of them, and don't forget the series resistor.Quote
TraumflugAn ATmega pin can sink 20 mA, which is sufficient for standard signal LEDs.Quote
jbernardis
The separately numbered pins are the analog input pins, not the PWM ("analog" output) pins.Quote
nophead
Aren't analogue pins numbered independently of digital pins? In which case how does the code work?
Re: MARLIN: M42 December 25, 2012 09:46AM |
