Autostart print from SD Card?
February 24, 2013 10:12AM
Hi all,
i'm looking for a way to make a printer automaticaly start printing once it is powered up.
It should just read a file from the SD and process it.
I'm currently using Marlin and it would be nice if there is a solution with that, but i'm open for other options as well.
Thanks in advance
Cheers
Björn
Re: Autostart print from SD Card?
February 24, 2013 12:25PM
I think if it finds a file on the SD card called auto0.g it will run it automatically. Once it has done that it will look for auto1.g, etc. I have never tried it.
February 24, 2013 01:23PM
Thank you, you were right, it does exactly that smiling smiley
February 26, 2013 01:19PM
Thaks nophead. I never knew that
October 05, 2016 07:36PM
This is great, thank you!
I use auto0.g to autostart the hotbed & extruder-- comes in handy while tweaking around with the firmware, reboots were frigid, brrr.
Now I do not have to poke around thru marlin ui after rebuilds, the hotties automatically return to hotness !!
yippee for improved shake rattle and roll
