Heater Problems w/Repetier Firmware on RAMPS 1.4 June 22, 2013 04:29PM |
/**************************************************************************************** * Arduino Mega pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 33 #define MOTHERBOARD 3 #define RAMPS_V_1_3 #elif MOTHERBOARD == 34 #define MOTHERBOARD 3 #define RAMPS_V_1_3 #define AZTEEG_X3 #endif #if MOTHERBOARD == 3 #define KNOWN_BOARD 1 //////////////////FIX THIS////////////// #ifndef __AVR_ATmega1280__ #ifndef __AVR_ATmega2560__ #error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu. #endif #endif // uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1 #define RAMPS_V_1_3 // #define RAMPS_V_1_0 #ifdef RAMPS_V_1_3 #define X_STEP_PIN 54 #define X_DIR_PIN 55 #define X_ENABLE_PIN 38 #define X_MIN_PIN -1 #define X_MAX_PIN 2 #define Y_STEP_PIN 60 #define Y_DIR_PIN 61 #define Y_ENABLE_PIN 56 #define Y_MIN_PIN -1 #define Y_MAX_PIN 15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 62 #define Z_MIN_PIN -1 #define Z_MAX_PIN 19 #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30 #define SDPOWER -1 #define SDSS 53 #define SDCARDDETECT 49 #define LED_PIN -1 #define FAN_PIN 9 #define PS_ON_PIN 12 #define KILL_PIN 41 #define HEATER_0_PIN 10 #define HEATER_1_PIN 8 #define HEATER_2_PIN -1 #define TEMP_0_PIN 13 // ANALOG NUMBERING #define TEMP_1_PIN 14 // ANALOG NUMBERING #define TEMP_2_PIN 15 #define E0_PINS E0_STEP_PIN,E0_DIR_PIN,E0_ENABLE_PIN, #define E1_PINS E1_STEP_PIN,E1_DIR_PIN,E1_ENABLE_PIN, #else // RAMPS_V_1_1 or RAMPS_V_1_2 as default #define X_STEP_PIN 26 #define X_DIR_PIN 28 #define X_ENABLE_PIN 24 #define X_MIN_PIN 3 #define X_MAX_PIN -1 //2 #define Y_STEP_PIN 38 #define Y_DIR_PIN 40 #define Y_ENABLE_PIN 36 #define Y_MIN_PIN 16 #define Y_MAX_PIN -1 //17 #define Z_STEP_PIN 44 #define Z_DIR_PIN 46 #define Z_ENABLE_PIN 42 #define Z_MIN_PIN 18 #define Z_MAX_PIN -1 //19 #define E0_STEP_PIN 32 #define E0_DIR_PIN 34 #define E0_ENABLE_PIN 30 #define SDPOWER 48 #define SDSS 53 #define LED_PIN 13 #define PS_ON_PIN -1 #define KILL_PIN -1 //#define SCL 21 //#define SDA 20 #define E0_PINS E0_STEP_PIN,E0_DIR_PIN,E0_ENABLE_PIN, #define E1_PINS #ifdef RAMPS_V_1_0 // RAMPS_V_1_0 #define HEATER_0_PIN 12 // RAMPS 1.0 #define HEATER_1_PIN -1 // RAMPS 1.0 #define FAN_PIN 11 // RAMPS 1.0 #else // RAMPS_V_1_1 or RAMPS_V_1_2 #define HEATER_0_PIN 10 // RAMPS 1.1 #define HEATER_1_PIN 8 // RAMPS 1.1 #define FAN_PIN 9 // RAMPS 1.1 #endif #define TEMP_0_PIN 2 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #define TEMP_1_PIN 1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #endif // SPI for Max6675 Thermocouple // these pins are defined in the SD library if building with SD support #define SCK_PIN 52 #define MISO_PIN 50 #define MOSI_PIN 51 #define MAX6675_SS 53 #ifdef AZTEEG_X3 #define SDSUPPORT true #define SDCARDDETECTINVERTED false #define SDCARDDETECT -1 #define FAN_PIN 4 #define FAN2_PIN 5 #define LIGHT_PIN 6 #define BEEPER_PIN 33 // Activate beeper on extension shield #define BEEPER_TYPE 1 #endif #endif
Re: Heater Problems w/Repetier Firmware on RAMPS 1.4 June 23, 2013 12:15AM |
Re: Heater Problems w/Repetier Firmware on RAMPS 1.4 June 23, 2013 01:31PM |
Re: Heater Problems w/Repetier Firmware on RAMPS 1.4 July 09, 2013 09:09AM |
Re: Heater Problems w/Repetier Firmware on RAMPS 1.4 July 09, 2013 10:55AM |
Re: Heater Problems w/Repetier Firmware on RAMPS 1.4 July 10, 2013 08:02AM |
Re: Heater Problems w/Repetier Firmware on RAMPS 1.4 July 10, 2013 08:42AM |
Re: Heater Problems w/Repetier Firmware on RAMPS 1.4 July 11, 2013 05:37AM |
