Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 July 07, 2013 05:35AM |
ultralcd.cpp: In function 'void lcd_init()': ultralcd.cpp:829: error: 'SHIFT_CLK' was not declared in this scope ultralcd.cpp:830: error: 'SHIFT_LD' was not declared in this scope ultralcd.cpp:831: error: 'SHIFT_EN' was not declared in this scope ultralcd.cpp:832: error: 'SHIFT_OUT' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_RPORT' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_WPORT' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_PIN' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_WPORT' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_PIN' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_WPORT' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_PIN' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_WPORT' was not declared in this scope ultralcd.cpp:833: error: 'DIOSHIFT_OUT_PIN' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_RPORT' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_WPORT' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_PIN' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_WPORT' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_PIN' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_WPORT' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_PIN' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_WPORT' was not declared in this scope ultralcd.cpp:834: error: 'DIOSHIFT_LD_PIN' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_RPORT' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_WPORT' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_PIN' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_WPORT' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_PIN' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_WPORT' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_PIN' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_WPORT' was not declared in this scope ultralcd.cpp:835: error: 'DIOSHIFT_EN_PIN' was not declared in this scope
WRITE(SHIFT_LD,HIGH);
#endif
#else
pinMode(SHIFT_CLK,OUTPUT); <-- This is where the error appears
pinMode(SHIFT_LD,OUTPUT);
pinMode(SHIFT_EN,OUTPUT);
pinMode(SHIFT_OUT,INPUT);
WRITE(SHIFT_OUT,HIGH);
WRITE(SHIFT_EN,LOW);
#endif//!NEWPANEL
Re: Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 July 09, 2013 04:07AM |
#define REPRAPWORLD_KEYPAD #define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click
#else
// pinMode(SHIFT_CLK,OUTPUT);
// pinMode(SHIFT_LD,OUTPUT);
// pinMode(SHIFT_EN,OUTPUT);
// pinMode(SHIFT_OUT,INPUT);
// WRITE(SHIFT_OUT,HIGH);
// WRITE(SHIFT_LD,HIGH);
// WRITE(SHIFT_EN,LOW);
#endif//!NEWPANEL
Re: Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 August 31, 2013 02:53AM |
Re: Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 August 31, 2013 03:03AM |
Re: Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 January 05, 2014 12:05PM |
Re: Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 January 19, 2014 10:18AM |
Re: Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 January 23, 2014 11:35PM |
Re: Marlin compile error when enabling ULTRA_LCD define with Megatronics 2.0 February 13, 2017 01:14PM |
