Marlin problems with M114, M117 Solved!
July 07, 2013 05:08PM
Problem wasn't Marlin. Problem was latest pronterface doesn't show returned message on M114 and M117. Pronsole does. Will try to find earlier pronterface.
Been away for a bit. Compiled new Marlin under Arduino 1.01, loaded, no problems. Everything works except text output to pronterface on M114 (get position) and M117 (send comment). Text output is fine from M119 (read endstops) and M115 (capabilities string). Went back to unmodified default marlin config file and only changed motherboard to 33 and baud rate to 115 and tried again. Same results. Is everything now defauted to LCD (which I don't have)?
I need 114 to help set default home position when homing Z to maximum.
Any thoughts?
Roger
Edited 1 time(s). Last edit at 07/08/2013 02:13PM by vrsculptor.
