SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. August 23, 2013 08:33AM |
* Arduino Mega pin assignment
#if MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34
#define KNOWN_BOARD 1
//////////////////FIX THIS//////////////
#ifndef __AVR_ATmega1280__
#ifndef __AVR_ATmega2560__
#error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
#endif
#endif
// uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1
#define RAMPS_V_1_3
// #define RAMPS_V_1_0
#if MOTHERBOARD == 33 || MOTHERBOARD == 34
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#define X_MIN_PIN 3
#define X_MAX_PIN 2
#define Y_STEP_PIN 60
#define Y_DIR_PIN 61
#define Y_ENABLE_PIN 56
#define Y_MIN_PIN 14
#define Y_MAX_PIN 15
#define Z_STEP_PIN 46
#define Z_DIR_PIN 48
#define Z_ENABLE_PIN 62
#define Z_MIN_PIN 18
#define Z_MAX_PIN 19
#define Z2_STEP_PIN 36
#define Z2_DIR_PIN 34
#define Z2_ENABLE_PIN 30
#define E0_STEP_PIN 26
#define E0_DIR_PIN 28
#define E0_ENABLE_PIN 24
#define E1_STEP_PIN 36
#define E1_DIR_PIN 34
#define E1_ENABLE_PIN 30
#define SDPOWER -1
#define SDSS 53
#define LED_PIN 13
#define FAN_PIN 9 // (Sprinter config)
#else
#define FAN_PIN 4 // IO pin. Buffer needed
#endif
#define PS_ON_PIN 12
#ifdef REPRAP_DISCOUNT_SMART_CONTROLLER
#define KILL_PIN 41
#else
#define KILL_PIN -1
#endif
#define HEATER_0_PIN 10 // EXTRUDER 1
#define HEATER_1_PIN -1
#else
#define HEATER_1_PIN 9 // EXTRUDER 2 (FAN On Sprinter)
#endif
#define HEATER_2_PIN -1
#define TEMP_0_PIN 13 // ANALOG NUMBERING
#define TEMP_1_PIN 15 // ANALOG NUMBERING
#define TEMP_2_PIN -1 // ANALOG NUMBERING
#define HEATER_BED_PIN 8 // BED
#define TEMP_BED_PIN 14 // ANALOG NUMBERING
#ifdef ULTRA_LCD
#ifdef NEWPANEL
//encoder rotation values
#define encrot0 0
#define encrot1 2
#define encrot2 3
#define encrot3 1
#define BLEN_A 0
#define BLEN_B 1
#define BLEN_C 2
#define LCD_PINS_RS 16
#define LCD_PINS_ENABLE 17
#define LCD_PINS_D4 23
#define LCD_PINS_D5 25
#define LCD_PINS_D6 27
#define LCD_PINS_D7 29
#define BEEPER 37
#define BTN_EN1 31
#define BTN_EN2 33
#define BTN_ENC 35
#define SDCARDDETECT 49
#else
//arduino pin which triggers an piezzo beeper
#define BEEPER 33 // Beeper on AUX-4
//buttons are directly attached using AUX-2
#define BTN_EN1 37
#define BTN_EN2 35
#define BTN_ENC 31 //the click
#define SDCARDDETECT -1 // Ramps does not use this port
#endif
#else //old style panel with shift register
//arduino pin witch triggers an piezzo beeper
#define BEEPER 33 No Beeper added
//buttons are attached to a shift register
// Not wired this yet
//#define SHIFT_CLK 38
//#define SHIFT_LD 42
//#define SHIFT_OUT 40
//#define SHIFT_EN 17
#define encrot0 0
#define encrot1 2
#define encrot2 3
#define encrot3 1
//bits in the shift register that carry the buttons for:
// left up center down right red
#define BL_LE 7
#define BL_UP 6
#define BL_MI 5
#define BL_DW 4
#define BL_RI 3
#define BL_ST 2
#define BLEN_B 1
#define BLEN_A 0
#endif
#endif //ULTRA_LCD
#else // RAMPS_V_1_1 or RAMPS_V_1_2 as default (MOTHERBOARD == 3)
#define X_STEP_PIN 26
#define X_DIR_PIN 28
#define X_ENABLE_PIN 24
#define X_MIN_PIN 3
#define X_MAX_PIN -1 //2
#define Y_STEP_PIN 38
#define Y_DIR_PIN 40
#define Y_ENABLE_PIN 36
#define Y_MIN_PIN 16
#define Y_MAX_PIN -1 //17
#define Z_STEP_PIN 44
#define Z_DIR_PIN 46
#define Z_ENABLE_PIN 42
#define Z_MAX_PIN -1 //19
#define E0_STEP_PIN 32
#define E0_DIR_PIN 34
#define E0_ENABLE_PIN 30
#define SDPOWER 48
#define SDSS 53
#define LED_PIN 13
#define PS_ON_PIN -1
#define KILL_PIN -1
#ifdef RAMPS_V_1_0 // RAMPS_V_1_0
#define HEATER_0_PIN 12 // RAMPS 1.0
#define HEATER_BED_PIN -1 // RAMPS 1.0
#define FAN_PIN 11 // RAMPS 1.0
#define HEATER_0_PIN 10 // RAMPS 1.1
#define HEATER_BED_PIN 8 // RAMPS 1.1
#define FAN_PIN 9 // RAMPS 1.1
#endif
#define TEMP_0_PIN 2 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#define TEMP_1_PIN -1
#define TEMP_BED_PIN 1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#endif// MOTHERBOARD == 33 || MOTHERBOARD == 34
// SPI for Max6675 Thermocouple
#ifndef SDSUPPORT
// these pins are defined in the SD library if building with SD support
#define MAX_SCK_PIN 52
#define MAX_MISO_PIN 50
#define MAX_MOSI_PIN 51
#define MAX6675_SS 53
#else
#define MAX6675_SS 49
#endif
#endif//MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. August 25, 2013 10:20AM |
#endif
#endif
#define RAMPS_V_1_3
#define X_MIN_PIN 3
#define X_MAX_PIN 2
#define SDPOWER -1
#define SDSS 53
#define LED_PIN 13
#else
#endif
#define KILL_PIN 41
#else
#define KILL_PIN -1
#endif
#ifndef SDSUPPORT
#else
#endif
#else
#endif
#ifdef ULTRA_LCD
#ifdef NEWPANEL
#define encrot0 0
#define encrot1 2
#define encrot2 3
#define encrot3 1
#define BLEN_A 0
#define BLEN_B 1
#define BLEN_C 2
#define BEEPER 37
#define BTN_EN1 31
#define BTN_EN2 33
#define BTN_ENC 35
#else
#define BTN_EN1 37
#define BTN_EN2 35
#endif
#define encrot0 0
#define encrot1 2
#define encrot2 3
#define encrot3 1
#define BL_LE 7
#define BL_UP 6
#define BL_MI 5
#define BL_DW 4
#define BL_RI 3
#define BL_ST 2
#define BLEN_B 1
#define BLEN_A 0
#endif
#endif //ULTRA_LCD
#define X_MIN_PIN 3
#define SDPOWER 48
#define SDSS 53
#define LED_PIN 13
#define KILL_PIN -1
#endif
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. August 29, 2013 06:16AM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. September 22, 2014 07:18PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. October 13, 2014 11:40PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. October 14, 2014 01:10PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. December 02, 2014 01:03PM |
Anonymous User
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. December 28, 2014 10:26AM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. January 17, 2015 03:49AM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. January 22, 2015 12:05PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. March 15, 2015 02:11PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. March 16, 2015 05:36AM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. March 29, 2015 01:09PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. March 31, 2015 10:25AM |
Solved using Partition Table Type "msdos" August 19, 2015 06:31AM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. December 15, 2015 06:39AM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. January 04, 2016 11:06AM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. February 15, 2016 11:14PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. October 16, 2016 01:08PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. January 08, 2017 09:29PM |
Re: SD card problems, Marlin+ramps1.4+reprapdiscount smartcontroller. March 13, 2017 03:38AM |
