separate steps per rotation X Y axis in marlin
November 02, 2013 07:01AM
i have build / i'm building a bigger printer ( print area 30 x 30 25 ) for ceramics. now the hardware is almost done and i'm doing same control tests. i don't have many programming skills and am running against a problem. in the marlin firmware the X and Y axes are using the same steps per rotation setup. in my printer i’m differed gears, belts for the y and ax is there a way to sprit the setup in the firm ware?
tnks
open | download - image.jpg (189.1 KB)
Re: separate steps per rotation X Y axis in marlin
November 02, 2013 12:55PM
No - in marlin each axis has its own steps per mm setting. The only common x y parameter I can think of is xy jerk, but there may be others. But I am certain that steps per mm is separate for each axis.
November 02, 2013 03:53PM
in my firmware i have this:
#define XY_MTR_STPS 156
in the configurations tab. i don't have x and y
November 04, 2013 12:09AM
I have a very recent download on Marlin, and that line is not in the configuration file - nor have I seen it in any versions I have previously downloaded.
I do, however, see this line:
#define DEFAULT_AXIS_STEPS_PER_UNIT {44.44,44.44,1600,699.897} // default steps per unit for Ultimaker
and you can see 4 separate values there for X, Y, Z, and E
Are you sure you are using marlin??
November 05, 2013 04:01AM
my marlin was original for a prusa, i no downloaded the last version of marlin and a’m able to change it.
now i have a homing problem, i'm trying to fix that now
tnks
