No x movement on marlin + sanguinalolu
Posted by hcker2000
December 01, 2013 09:14AM
When I try to use the left or right x jog buttons in pronterface nothing happens.
I'm running marlin on a sanguinalolu board.
I have confirmed wiring is fine by hooking the motor to the y axis and using the y jog and that works fine. I also swapped the x driver to the y spot to make sure the driver is ok and it is.
Any thoughts?
Edited 1 time(s). Last edit at 12/02/2013 03:45PM by hcker2000.
Re: No x movement on marlin + sanguinalolu
December 04, 2013 09:47AM
I got this issue resolved.
Some how line #281 of the configuration.h file was set to #define X_ENABLE_ON 1 and needed to be #define X_ENABLE_ON 0
