So far the problems seem to be with some confusion over the header files Arduino.h, WProgram.h, Pins when compiling with the Z servo option set Both Midge and myself have been looking at these problems for a while now.. If anyone has managed to build the the Z servo option on a Sanguino(lolu) please could you point me to the git hub revision you used.. and possibly the enviroment required/used to build ..
For example we had to add these lines into Pins_Arduino.h
//BM added as was missing for SPI
static const uint8_t SS = 10;
static const uint8_t MOSI = 11;
static const uint8_t MISO = 12;
static const uint8_t SCK = 13;
// end old pins definitions
And into Servo.ccp we added the if then statments to inclued Arduino.h, WProgram.h
My version of code compare has startedted to warm up now.. from use..
We have tried the standard Marlin V1 and the Smartrap revision to no availl..
Bodge It [
reprap.org]
My rep strap: [
repstrapbertha.blogspot.com]
Buy the bits from B&Q pipestrap [
diyrepstrap.blogspot.com]
How to Build a Darwin without any Rep Rap Parts [
repstrapdarwin.blogspot.com]
Web Site [
www.takeaway3dtech.com]
