Pronterface connection issue (early stages) April 25, 2014 10:44PM |
Re: Pronterface connection issue (early stages) April 27, 2014 12:39AM |
Re: Pronterface connection issue (early stages) April 27, 2014 03:25AM |
DaveX
Check serial ports and baud rates.
If you have been able to flash/try different versions of Marlin, then it sounds like you can get communication between the Arduino and the computer.
Re: Pronterface connection issue (early stages) April 27, 2014 10:11PM |
Re: Pronterface connection issue (early stages) April 28, 2014 04:24AM |
DaveX
What the arduino itself thinks is com3 is very different than what the host computer thinks is com3. You likely want your computer's com3 to talk to the arduino's com1
See [arduino.cc] and the Input Output section where "Serial 3" is on pins 15 and 14, which are what RAMPS uses for the Y endstops.
Re: Pronterface connection issue (early stages) April 30, 2014 05:36AM |
