Firmware fix for direct drive
February 01, 2010 01:09AM
In the current FiveD firmware SVN 3417
[reprap.svn.sourceforge.net]
If MOTHERBOARD=1 (direct drive) in configuration.h then compiling fails with this error:
Error in extruder.pde
In member function 'void extruder::waitForTemperature()':
error: 'target_celcius' was not declared in this scope In function 'void process_string(char*, int)':
Changing the name to "target_celsius" fixes that error.
There is a new error because of the recently added M110 code for the extruder is meaningless on a direct drive firmware. It needs an #if to fix.
Error in process_g_code.pde
error: 'class extruder' has no member named 'usePotForMotor
-----extruder.pde-------
case 110:
#if MOTHERBOARD == 2
ex[extruder_in_use]->usePotForMotor();
#endif
break;
This now compiles for MOTHERBOARD=1
Now back to MOTHERBOARD=2 now has new errors with "target_celsius". Amazing that this error mutually exclusive!
In "extruder.h" two occurances of "target_celcius" should be replaced with "target_celsius"
Now there is no errors.
