Setting Up CoreXY on Marlin
Posted by Jeepguy42
October 08, 2014 03:17PM
I've designed and am in the process of building an upgrade to a 3D printer I've had for almost a year now. The new printer design will be using a CoreXY setup. I'm about to the point where I'll need to update the firmware to run CoreXY settings. Is activating/turning on the CoreXY functionality for the latest version of Marlin as easy as just removing the two "//" from the configuration.h file infrom of the CoreXY
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
I want to make sure I'm looking at everything I need to to get it working properly and only have limited knowledge of the marlin firmware
Edited 2 time(s). Last edit at 10/08/2014 03:22PM by Jeepguy42.
