can't compile with full graphics smart controller
Posted by Ted62
January 15, 2015 04:34PM
I have just installed a reprap discount full graphics smart controller.
I've downloaded U8Lib and installed to my documents\arduino\libraries folder.
I've uncommented the line 564 in configuration.h
#define REPRAP_DISCOUNT_FULL_GRAPHICS_SMART_CONTROLLER
When I compile I get the following error:
'LONG_FILENAME_LENGTH' was not declared in this scope
If I comment out #define REPRAP_DISCOUNT_FULL_GRAPHICS_SMART_CONTROLLER
the program compiles with no errors.
Attached my configuration.h file
Anyone any idea what I am doing wrong?
open | download - Configuration.h (35.3 KB)
Re: can't compile with full graphics smart controller solved
January 16, 2015 06:41AM
I am using a newly downloaded Marlin-Development firmware available from [github.com].
After a lot of searching through the long list of errors I found an error indicating that SDfile.cpp could not be found.
Checking the files in the Marlin directory showed the file was not there.
Checking my library files using Sketch > Import Library showed they were not in my sketchbook library or the Arduino main library.
Checking all the files in the download I found the missing files in Arduino Addons\Arduino_1.0x\libraries\SDfat. the libraries directory also contains the U8glib, Liquid crystal and SPI library files.
After installing the library files using Sketch > Import Library > Add Library the program compiles with no errors.
I have tried to find any instructions or explanation as to where the necessary library files are, or what files are needed to compile the various versions of graphics/LCD's, e.g. All the instructions I have found for installing the REPRAP_DISCOUNT_FULL_GRAPHICS_SMART_CONTROLLER only state remove the comments (//) from the //#define REPRAP_DISCOUNT_FULL_GRAPHICS_SMART_CONTROLLER line.
Hope this helps if anyone else encounters the problem
November 12, 2016 09:29PM
did u find the solution ?? i having same issue if you could help me ?
November 13, 2016 07:18AM
All of the lines below should be uncommented. Make sure you installed U8glib properly.
#define DOGLCD
#define SDSUPPORT
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
