Newbie - GADGETS3D Shield with Panel problem May 16, 2015 06:49AM |
/ The GADGETS3D G3D LCD/SD Controller (blue PCB ) // [reprap.org] #define G3D_PANEL
Re: Newbie - GADGETS3D Shield with Panel problem May 16, 2015 08:33AM |
// include the library code: #include <LiquidCrystal.h> // initialize the library with the numbers of the interface pins LiquidCrystal lcd(16, 17, 23, 25, 27, 29); void setup() { // set up the LCD's number of columns and rows: lcd.begin(16, 2); // Print a message to the LCD. lcd.print("hello, world!"); } void loop() { // set the cursor to column 0, line 1 // (note: line 1 is the second row, since counting begins with 0): lcd.setCursor(0, 1); // print the number of seconds since reset: lcd.print(millis() / 1000); }
Re: Newbie - GADGETS3D Shield with Panel problem May 16, 2015 05:47PM |
Re: Newbie - GADGETS3D Shield with Panel problem May 16, 2015 06:43PM |
